Is it safe to read the boost level on the vafc if you are running the hack?
Old Jul 25, 2003 | 11:12 AM
T3T495GSR's Avatar
Default Is it safe to read the boost level on the vafc if you are running the hack?
i just noticed the other day that you can read the boost on the vafc ( PRS ). Is this correct or safe if im running the vafc hack? doesnt PRS only read MAP voltage and arent i tricking the map running the hack? so is it dangerous to rely on what teh vafc says for prs? cuase garage kwai says im tuned at 8 psi and it came up to around .54 which is almost 8 psi so is this safe?
sorry for the sorta noob question
Old Jul 25, 2003 | 11:33 AM
T3T495GSR's Avatar
Default Re: Is it safe to read the boost level on the vafc if you are running the hack? (T3T495GSR)
TTT
Old Jul 25, 2003 | 12:33 PM
rioninja's Avatar
Yes the vafc displays the map input, so its fairly accurate.
Old Jul 25, 2003 | 12:48 PM
Accord94DX's Avatar
Default Re: Is it safe to read the boost level on the vafc if you are running the hack? (rioninja)
Me and a couple other guys on here notice that the VAFC/SAFC reads a lower amount of boost than there really is. Check it out: https://honda-tech.com/zerothread?id=571191
Tactic$
Dec 28, 2005 01:56 PM
teamitr
Mar 10, 2005 09:29 PM
hatchedzex
Dec 23, 2004 10:48 AM
othick
Jul 11, 2003 04:42 PM
dbman96
Nov 1, 2001 11:22 AM
