Safe pressure for GSR motor
Old 07-26-2006, 12:39 AM
DOHC Vtec Turbo's Avatar
Default Safe pressure for GSR motor
Is 8.7lbs safe on a GSR motor? i did a compression check and everything was still good 195-200psi. The turbo is a gt30r. I was wondering I should lower the boost or what not.
Old 07-26-2006, 01:10 AM
Timmay's Avatar
Default Re: Safe pressure for GSR motor (DOHC Vtec Turbo)
dont worry about boost PSI.. worry about HP levels and tuning
people have ran 30lbs on stock gsr motors.. but its all in the setup and tuning
8lbs will be fine with a good fuel pump and injectors .. make sure to have a tuner who knows what they are doing
Old 07-26-2006, 01:47 AM
Default Re: Safe pressure for GSR motor (Timmay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Timmay &raquo;</TD></TR><TR><TD CLASS="quote">dont worry about boost PSI.. worry about HP levels and tuning
8lbs will be fine with a good fuel pump and injectors .. make sure to have a tuner who knows what they are doing</TD></TR></TABLE> so what hp level is safe? injectors are 440cc rcs and fuel pump walbro 255 going to be tuned on crome.
Old 07-26-2006, 01:57 AM
Timmay's Avatar
8lbs pending on turbo should net you around 275whp.. id say on pump gas and a conservative tune i would say 300whp-325 is plenty safe
Old 07-26-2006, 02:18 AM
its a gt30r turbo
jlfrnce
09-05-2007 12:54 PM
gsr x civic
10-30-2006 11:21 AM
95dc2teg
07-16-2006 12:58 PM
playalistic2
09-16-2005 11:53 AM
maxheat
04-02-2005 01:27 AM
Quick Reply: Safe pressure for GSR motor
