safe boost level
Old Oct 24, 2009 | 10:33 AM
  #26
4drEF's Avatar
Keyboard Humorist
Default Re: safe boost level
Originally Posted by northemt88
post something good for once in your life!!!!!
X2
Post more pics of the girl in your avatar!
Old Oct 24, 2009 | 03:12 PM
  #27
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Here are more pictures of his girlfriend as requested... (the one on the right in the pink if you didn't know)
Old Oct 24, 2009 | 04:20 PM
  #28
4drEF's Avatar
Keyboard Humorist
Whew - thought you were going to post this one
Old Oct 24, 2009 | 04:22 PM
  #29
D16SiHatch's Avatar
oh.. my lord ^
not sure if even kittens can save this thread.. but here goes nothin lol
Old Oct 24, 2009 | 04:42 PM
  #30
DO IT ON ALL FOURS
!!! OMFG !!!
I just punched myself in the face...
Old Oct 24, 2009 | 04:44 PM
  #31
DO IT ON ALL FOURS
My head is still spinning...
Old Oct 24, 2009 | 06:57 PM
  #32
masterEF's Avatar
lol at images but back to business
but thanks for the info
i was asking because im using the car as a DD
and i was wondering whether i should flash the ecu or go to an actual dyno
Old Oct 24, 2009 | 07:15 PM
  #33
pauld's Avatar
As a side note, I did a d16z6 for a friend a year ago as his daily driver, stock rebuilt bottom end, and we ran it at 11psi from a Jackson racing superchager (non intercooled). Being non intercooled is quite hard on things, but he stomps on it daily, and it hasnt had a single issue yet. Its decently tuned, and has the appropriate fuel mods ( injectors, pump, ecu chipped), so I'd say do 10-11 psi intercooled and you'.ll be ok. Ive tuned a couple of d16a6's running between 10-13psi on the stock bottom end too. Both had mucho miles on them before getting boosted. They were fine too.
Old Oct 24, 2009 | 10:30 PM
  #34
pettyboy69's Avatar
man new threads every day and everyone keeps saying the same thing
PSI MEANS NOTHING!!! you can't say "oh ya your motor is good for 10 psi" cuz i promise you if you bolted a gt35r onto a stock single cam and ran 10lbs you would scatter your rods all over the road.
Every turbo is different and flows differently 10psi on my borg warner s372 will make over 400hp on a built motor as a dsm turbo on 10psi will make bout 150hp
DO RESEARCH BEFORE ASKING THE SAME DAMN QUESTION OVER AND OVER AND OVER!
that is all
Old Oct 25, 2009 | 05:57 AM
  #35
Silva Bullit DC4's Avatar
that is all
AMEN...[/thread]
To the OP...State what SIZE (or trim) t3/t04 turbo you have for your car. That will tell alot, as psi will render itself rather irrelevant because different size turbos make different power at the same pressure level. Psi is just the level of pressure thats measured at the intake manifold & MAP sensor.
Alot of general "rules of thumb" are set here on H-T, and the one that seems suitable for your engine (thru experience of course), is a 200 to 225 whp "safe" limit. Always set a power goal for yourself, not a psi goal, and if you are comfortable with taking your D15 to that power level, discuss it with your tuner, and he will use whatever psi your setup will give him to make that power goal. Good luck.
Old Oct 25, 2009 | 06:40 PM
  #36
masterEF's Avatar
so i should put 210hp to get 180whp and i dont need to care about what psi i get right?
Old Oct 26, 2009 | 04:52 AM
  #37
The driveline loss will depend on what dyno you're gonna be tuning on. Dynapacks measure bhp. Chassis dynos measure whp (ie: Dynojets, Mustangs, etc.). Also take into consideration weather and temperature conditions. Will the car be tuned on a dynapack?
As far as psi in your case, Im gonna say yes, because Im assuming you have the properly sized t3/t04 for your engine and power level. THAT is the key to a good setup and tune. In cases when the properly sized turbo is not chosen (for ex: a small turbo going out WAY of its efficiency range), it may not be able to sustain enough pressure at the intake manifold to make a particular tagreted power goal, then the turbo will push out an extremely high temp air charge which can lead to high EGT's, high cylinder pressures and detonation.
Others may chime in that can explain it a little better than I can, but you get he idea.
Old Nov 6, 2009 | 09:16 PM
  #38
northemt88's Avatar
Originally Posted by ALLxMOTOR EG
That was a good post.
Tuning is the key when boosted.
I answered his question, he asked is 10 psi pushing it?
My answered was get a good tune.
that was a good post,but all your other ones are keep it up,looks good.way to increase your post
Old Nov 10, 2009 | 05:56 PM
  #39
masterEF's Avatar
hey i was wondering if it would be the same thing if i just get a pm6 chip with preprogrammed boost settings or do i need to take it to a tuner no matter what?
GSR_Hatch711
Feb 3, 2009 07:01 PM
teddy_dc2
Aug 6, 2006 07:10 AM
hb_rule_b18
Jun 28, 2005 04:03 AM
94lsboost
May 23, 2005 06:55 AM
gritsak
Jul 8, 2004 09:43 PM
