Safe amount of boost on auto
Old Oct 10, 2006 | 03:09 PM
Spoogen_1's Avatar
Default Safe amount of boost on auto
I have a 98 auto LS and I plan on swapping the tranny sometime down the line but not anytime soon. Im curious to know (IF I BOOST) whats a safe amount of psi I ran run without hurting the tranny. Someone told me like 3-4 pounds. I just wanna know if thats true.
Old Oct 10, 2006 | 04:59 PM
StckOnHvyChcks's Avatar
I've seen a turbo CB7 run 13's that was an automatic.. Not exactly sure if there was any mods to the tranny but i know he was makin over 200WHP
Old Oct 10, 2006 | 06:33 PM
y7turbo's Avatar
Default Re: Safe amount of boost on auto (Spoogen_1)
im not sure if the b-series auto is weaker or stronger then the d-series , so i can only talk about my old d-series auto. i had a d-series auto trans and i ran mine with up to 13lb of boost for a long time. before i had a turbo i was running a 75 shot of nitrous for over 25 bottles.
it had 100k miles when i converted to a 5 speed but i sold it. the new owner of my old auto transmission says its working perfectly.
tip: use honda auto trans fluid and change it often.
Old Oct 10, 2006 | 07:56 PM
EJ1_Sleeper's Avatar
Default Re: Safe amount of boost on auto (y7turbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by y7turbo &raquo;</TD></TR><TR><TD CLASS="quote">im not sure if the b-series auto is weaker or stronger then the d-series , so i can only talk about my old d-series auto. i had a d-series auto trans and i ran mine with up to 13lb of boost for a long time. before i had a turbo i was running a 75 shot of nitrous for over 25 bottles.
tip: use honda auto trans fluid and change it often. </TD></TR></TABLE>
Holy crap 13lb on a stock D Trans ? Which trans and what motor was it on. and did you get the trans new or used before you installed spray?
Old Oct 11, 2006 | 03:15 PM
y7turbo's Avatar
Default Re: Safe amount of boost on auto (moops vs moors)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by moops vs moors &raquo;</TD></TR><TR><TD CLASS="quote">I have absolutely no proof to back this up but it seems like the boosted autos that last are the ones that aren't launched but rather the power rolled on after the car is moving.
BTW don't use psi as a reference, use power. psi is meaningless unless there was only one turbo ever made.</TD></TR></TABLE>
Funny you talk about the trans lasting on those who dont launch hard often. I had those same thoughts, but never really looked into it further. I also think thats the reason why mine lasted. the frequent honda atf fluid changes im sure helped some as well.
well i never went to the dyno on my t3 setup. it was a t3-60trim on 13psi. go ahead and guess what whp that was on a d16y7. i would have to guess around 160whp for the auto trans..
JKov240
Honda Civic (2001 - 2005)
Apr 13, 2008 09:26 PM
'Accord Ex'
Apr 30, 2007 06:58 PM
Bird333
Feb 21, 2006 11:37 AM
X2BOARD
Apr 27, 2005 03:00 PM
eymnewdc4
Aug 4, 2004 06:53 PM
