Is It Safe?
Old Aug 6, 2011 | 04:37 PM
Hobkins's Avatar
Default Is It Safe?
I've had my 2000 Civic Si tuned not to long back then my transmission had problems and required to be removed and fixed... at that time the car went back on the blocks as we fixed it and we decided to upgrade some turbo parts. Well I'm curious if the car is safe to drive on short trips around to test it to see if any small things give us trouble. I'd rather get these small problems fixed at home rather then sitting on a dyno with a tuner waiting on us.
At the same time I'd rather have small problems on the dyno then have detonation or any other serious problem that can compromise my whole build for just road testing. I know tunes are incredibly important and infact my next tune date is August 17th so don't think I'm trying to convince you to convince me that I don't need a retune. So let me know what you guys think.
The parts we've changed from old tune are in red...
Stock B16A2
Block bored .20 over
SRP 9.1:1 Pistons
Eagle H Beam rods
All seals and gaskets are OEM Honda.
GSR Cams
Megan Cam Gears
Clutch Masters Stage 3
Turbonetics t3/t4 .57 trim .63a/r (Bad Bearings) ---> Turbonetics t3/t4 .57 trim .63 a/r (Brand New)
Blox log manifold ---> Full Race A/C Ramhorn
Cheapo Wastegate 11 PSI Spring ---> 38mm Tial Wastegate 10 PSI spring
Greddy Bov
RC 550cc injectors
2.5" Downpipe ---> 3” Full Race Downpipe
2.5" Exhaust W/ Catalytic Converter ---> 3” Thermal Research and Development Exhaust no Catalytic Converter
Drag i/c 6.5” height
Hondata S300
Stock Radiator Fan ---> 13" Spal Puller Radiator Fan
Stock Condensor Fan ---> 13" Spal Puller Condensor Fan
Let me know if you need any other information.
Old Aug 6, 2011 | 08:03 PM
civickiller's Avatar
Default Re: Is It Safe?
yes i think you need a retune
Old Aug 6, 2011 | 09:17 PM
TheShodan's Avatar
Moderator
But yes, you can drive around (responsibly) a bit to see if things are stable. Then retune
Old Aug 6, 2011 | 11:14 PM
Hobkins's Avatar
Very good to know thanks!
Old Aug 7, 2011 | 07:06 PM
wunfstgsr's Avatar
Loved
Community Favorite
use your tune as a base map to drive around and check for leaks and ect, dont boost even at all just stay out of boost then get tuned.
Double_Trouble_99
12
Jun 14, 2010 08:46 PM
taildragger
Dec 15, 2008 01:52 PM
B18civicsi00
Mar 4, 2007 12:58 AM
johncarlos
Jan 28, 2004 11:38 AM
jinxproof99
Apr 20, 2002 11:18 AM
