Blue wire method
Old Apr 21, 2002 | 07:34 PM
vtecsiqt's Avatar
Default Blue wire method
How do you hook up the blue wire to get the o2 reading on a 94 B18b?
Old Apr 21, 2002 | 08:53 PM
Paul Walker's Avatar
Default Re: Blue wire method (vtecsiqt)
I'm assuming you're talking about a AFC. If so run the blue wire off the AFC to the o2 wire on the ecu. To read the O2 sensor voltage goto the main menu scroll down to and select the etc. menu. Select the sensor check. Of the three readings, O2 voltage will be the middle one (#2). You will be set.
Old Apr 22, 2002 | 12:10 AM
shadowdawn's Avatar
Default Re: Blue wire method (Paul Walker)
Any idea where to get a wire diagram for odb2 99 integra LS automatic? apexi's manual only shows which wire your supposed to be using, not nice enough to through which wire is the o2 wire in there
Old Apr 22, 2002 | 12:48 AM
inspyral's Avatar
Default Re: Blue wire method (shadowdawn)
I think it's the fat white wire to the ECU. Or, you can just run it to the O2 itself.
slammedz6ef
Feb 15, 2008 07:46 AM
hksdrager
May 11, 2007 07:55 PM
dsm this
Mar 15, 2004 02:42 AM
Urban Business
22
Sep 2, 2003 05:52 PM
fastcrxs1
May 23, 2002 04:11 PM
