vafc sensor voltage question
Old May 15, 2003 | 07:38 PM
_Endless_'s Avatar
Default vafc sensor voltage question
i'm using the hack right now and boosting 7psi. i recently checked my sensor voltage with the key in the ON position. may tps reads 0.4+ but my pressure/map reads 2.8something...is that normal? i step on the throttle and the tps increases gradually but the pressure voltage just stayed there. i thought pressure should be 0 volts without stepping on the gas pedal. so what should it be?
Old May 16, 2003 | 10:27 AM
rrei's Avatar
Default Re: vafc sensor voltage question (_Endless_)
with my car running my voltage is 0.8, it is 2.8 with the key on
Old May 16, 2003 | 06:24 PM
_Endless_'s Avatar
Default Re: vafc sensor voltage question (rrei)
with the engine idling it reads 1.3V is that normal?
Initial_drift
May 18, 2008 07:31 PM
jdmcivicferio
15
Jul 5, 2005 10:35 PM
Revi
Jul 9, 2004 10:00 AM
glock
Oct 19, 2002 02:29 PM
