saab turbo
Old May 14, 2003 | 01:11 PM
solsteeler's Avatar
Default saab turbo need help!
hey guys, just got a saab turbo from one of techs. he has no idea what size it is. all i know is that it is a garrett. it might be off of a 89-90 900. anybody have an idea what size it is? tknxs
Old May 14, 2003 | 01:20 PM
stackz's Avatar
at the jetties fishin'
Community Builder
Default Re: saab turbo need help! (solsteeler)
if I rememger correctly it's either a .40 or .45 trim turbo...nice quick spooler but craps out after about 15-17psi or so....
Old May 14, 2003 | 03:51 PM
solsteeler's Avatar
Default Re: saab turbo need help! (stackz)
thnxs for the info
Old May 14, 2003 | 04:12 PM
b16ahybrid's Avatar
Or it could be the smaller t3 .48 on exhaust side and .42 on compressor side. perfect for sohc turbo set-ups, crappy for dohc set-ups if intercooled. I ran one for a while on a sohc and a dohc.
Old May 14, 2003 | 04:23 PM
solsteeler's Avatar
Default Re: saab turbo need help! (b16ahybrid)
thnxs for the input. i,m going to contact saab, and see if one of the #'s will work off the turbo.
Old May 14, 2003 | 04:27 PM
b16ahybrid's Avatar
It will say on the housing, look on the exhaust housing for a .48 or any other number.....
Old May 14, 2003 | 04:51 PM
solsteeler's Avatar
thanks again, i'll let you know what i find out.
Old May 14, 2003 | 05:19 PM
stackz's Avatar
Community Builder
yeah sometimes the a/r is on the inside of the compressor outlet(area you see the blades).
but not always
Old May 14, 2003 | 06:11 PM
kommon_sense's Avatar
Is there a tag on the turbo with the part number or model number? You can usually look that info up and find the specs.
Old May 14, 2003 | 07:11 PM
BoostedD15B7's Avatar
Default Re: saab turbo need help! (kommon_sense)
B16Ahybrid.........
How much boost will the .48 .42 handle before spiking bad and crapping out.
Old May 14, 2003 | 09:13 PM
b16ahybrid's Avatar
Default Re: saab turbo need help! (BoostedD15B7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedD15B7 &raquo;</TD></TR><TR><TD CLASS="quote">B16Ahybrid.........
How much boost will the .48 .42 handle before spiking bad and crapping out.</TD></TR></TABLE>
depends on the engine. For a sohc you could probably run 12psi with no problems.It's probably the happiest between 8-12psi (most efficient).
For a dohc i don't even recomend it. If it's a low boost application without intercooler then it's fine up to about 5psi no more. it would be good for auto x where you need instant spool but not a lot of power. If your runing it on a street car and want some decent use (power) out of it you'll need to run more boost but you'll need a intercooler because it will heat up the charge temp fast. What i've noticed is people who run this turbo on a dohc (b16 and b18) with an intercooler have lots of pressure loss. I would lose about 3-4psi (from about 8psi, then would drop off to about 4psi by redline). Some people have run this turbo up to about 8psi non-intercooled and experienced no (or minimal) pressure loss. I know it was the turbo running out of stean (out of it's efficiency range and not able to provide enough boost pressure) and not a leak somwhere because for one i had my intercooler pressure tested, two 4 others with simular set-ups (same engine,turbo,and intercooled) experienced the same problem, three i swapped turbo's and the problem went away ( i didn't change anything else)....
IMO this turbo runs on a sohc (d15 or d16) nicely, and acts (spools and makes power) like a medium sized t3t4 does on a dohc....My d15b7 made 139whp on 5psi of boost, not a ton of power but good for only 5psi and no fuel management
Old May 15, 2003 | 06:59 AM
Cool....im running it on a D15B7.....Im planning on running 12 to 14psi in the future though and i am scared thats not gonna do it. Will i loose much spoolup by going to a T3/T4 with a .48 ex
Old May 15, 2003 | 07:10 AM
b16ahybrid's Avatar
not sure, i've never ran a t3t4 on a sohc............but i'd imagine for higher boost applications it would be good
Old May 15, 2003 | 08:50 AM
solsteeler's Avatar
checked the turbo again today after spraying it down with cleaner it's a .48 trim. don't know if it's worth using needs to be rebuilt. the shaft is locked up. my tech says he can do it,but i'm still unsure. i wanna thank you guys for all the help. nobody responds to my questions on the other forums.
Old May 15, 2003 | 08:21 PM
b16ahybrid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solsteeler &raquo;</TD></TR><TR><TD CLASS="quote">checked the turbo again today after spraying it down with cleaner it's a .48 trim. don't know if it's worth using needs to be rebuilt. the shaft is locked up. my tech says he can do it,but i'm still unsure. i wanna thank you guys for all the help. nobody responds to my questions on the other forums.
Anytime man, thats what we're here for.
notsolfast
Nov 18, 2011 12:23 AM
blackeg
May 18, 2008 06:20 PM
Perfourmance
Jan 8, 2006 11:23 PM
yusoslo
Feb 10, 2004 02:55 PM
