S-AFC hack, again....
Old Apr 22, 2002 | 06:38 AM
genop's Avatar
Default S-AFC hack, again....
I have a question about the s-afc hack.
I will have 450cc injectors, do I need to get a FMU, or will the afc be able to
handle everything. The way I understand it is that with the afc, you can tune up
to about 10 PSI without the aid of an FMU with 450cc injectors.
Mike
Old Apr 22, 2002 | 06:41 AM
TurboSohc's Avatar
Default Re: S-AFC hack, again.... (genop)
Like I have said before your playing with fire. The S-AFC was never created to do what your doing. I dont think you need the fmu or inline pump just the injectors and the S-AFC. Your car is gonna iddle very shity. Honestly why not sell the AFC for around $300 then invest that into a hondata and know you have that piece of mind and your doing it the right way. Good luck man check out stage2B at http://www.hondata.com
Old Apr 22, 2002 | 06:57 AM
5 Liter Eater's Avatar
You don't need an FMU. The 450's and AFC will be able to handle it.
Old Apr 22, 2002 | 07:41 AM
DSF's Avatar
DSF
Default Re: S-AFC hack, again.... (TurboSohc)
My car idles like stock with 450's and VAFC. Even with my FP @44psi (no vac). I really need to swap out my stock DX pump. It just can't handle my fuel needs
Old Apr 22, 2002 | 08:18 AM
genop's Avatar
Could you explain why exactly I am playing with fire? I realize that it was not created to do what people are doing with it, but many people have done it and gotten a good idle. I would say that it is better than relying on an FMU and high fuel pressures......I know hondata is much better, but I am in college and dont have the money to spend on a system like that, especially since I am only going to be running about 6 PSI....If there is a reason that the AFC hack is a bad idea, then please post it because I would like to know.
Mike
Default Re: S-AFC hack, again.... (DSF)
Ditto.
Old Apr 22, 2002 | 08:25 AM
MDA's Avatar
MDA
New User
Default Re: S-AFC hack, again.... (5 Liter Eater)
I also have the S-AFC ... but i run 550cc injectors... (Pintle style) and it idles fine... However the warmup (about 1 minute) at startup idles fine... but if I hit the gas you can tell there is a misfire... but after that 1 minute.. this are fine.
With that said... this is still a hack... and I wouldnt do it again. I'd look to another electronic solution.. because personally i dont like the FP solutions either.
Old Apr 22, 2002 | 06:09 PM
slywfbpsi's Avatar
Default Re: S-AFC hack, again.... (MDA)
you are running 550cc with the afc? Is this on a honda?
Old Apr 22, 2002 | 06:34 PM
Smashback's Avatar
Ditto.
Ditto.
[Modified by mplex2000, 3:35 AM 4/23/2002]
Old Apr 24, 2002 | 08:43 AM
MDA's Avatar
MDA
New User
Default Re: S-AFC hack, again.... (slywfbpsi)
Yes it's on a honda .... B18B.
Old Apr 24, 2002 | 09:00 AM
dwilson's Avatar
Would u mind sharing some of the settings u are using for the 550 injectors . I was under the impression that the AFC wouldnt back off enough to run with 550. If that is the case is it safe to say that u can exceed the 10psi with 550's without throwing a CEL.
Old Apr 24, 2002 | 09:32 AM
dbman96's Avatar
New User
Default Re: S-AFC hack, again.... (dwilson)
Considering I could get the 450s to start and idle anywhere between -25% and -50%, I think 550s are easily within the adjustment range. If you have trouble, drop your idle FP a little.
T3T495GSR
Apr 7, 2003 09:38 PM
untitled
Mar 19, 2003 06:27 AM
pelotudo
Sep 9, 2002 08:52 PM
ceemarun
May 29, 2002 10:50 AM
4gvtec
May 19, 2002 09:18 AM
