S-AFC Hack
Old Aug 27, 2002 | 08:43 AM
dwilson's Avatar
Default S-AFC Hack
Hey guys i was just wondering if anyone was using the hack on a LS and if anyone was actually pushing 10 psi or more with it? I have seen a couple of people running it on SOHC motors, but not actually on the DOHC motors.
Old Aug 27, 2002 | 09:12 AM
ion_four's Avatar
Default Re: S-AFC Hack (dwilson)
it works just the same, zojiroshi (rushi?) is running it on his LS and it seems to work. the logic is that you can't push much more than 10psi with the hack, because with 450cc's you will either run out of fuel or your MAP sensor will stop reading as it's rated at 2bar (~14.7lbs of boost)...
Old Aug 27, 2002 | 10:08 AM
BoostedSi's Avatar
Default Re: S-AFC Hack (ion_four)
I thought it was rated at 11-12psi?
turboegg
May 2, 2003 04:32 AM
KoRE
Sep 3, 2002 10:05 PM
vtecsiqt
Jun 30, 2002 09:43 PM
dwilson
Jun 5, 2002 04:49 PM
willyboyK20
Mar 14, 2002 05:43 AM
