running Zero lbs of boost cause engine problems?
Old Jul 16, 2004 | 08:44 PM
Snail Tuning's Avatar
Default running Zero lbs of boost cause engine problems?
ok hears my problem would running a stock ECU and fuel system on a turbo kit with the wastage held open. (internal wastegate aculater removed). would this cause any engine damage? im wandering because i need an eprom programer, and im going on vacation on monday, and i need my car. ill have the kit finished up but i won't have any upgraded fuel. can i drive the car on 0 boost or can i cause damage?
thanks
Old Jul 16, 2004 | 09:13 PM
Tchleung's Avatar
Default Re: running Zero lbs of boost cause engine problems? (bmcc72)
swap to a normal intake and elt the turbo charge pipes free flow into the atmosphere as well. iot should run fine. jsut be slow
Old Jul 16, 2004 | 09:17 PM
Default Re: running Zero lbs of boost cause engine problems? (Tchleung)
woudl running the charge pipes normal cause any problems?
Old Jul 17, 2004 | 02:44 AM
Tchleung's Avatar
I'm not certain but I would think it would jsut choke the intake more then the exhaust already is. But might work fine
Old Jul 17, 2004 | 06:27 AM
anyone else? i don't see why it would cause any engine or turbo damage but mabye im missing something!
Old Jul 17, 2004 | 06:30 AM
B18C1CYA's Avatar
just leave all your pipes hooked up and just hold the wastegate open, cus if you dont hold the gate open and unhook the pipes you could over spin the turbo and do damage to it
Old Jul 23, 2004 | 09:32 PM
Default Re: running Zero lbs of boost cause engine problems? (B18C1CYA)
bump cause im back from vacation and i still have no money for an eprom burner. so will running a stock map with the wastegate open will this cause any problems???????
Old Jul 23, 2004 | 10:34 PM
Turbo E's Avatar
probably run crappy, but no damage IMO.
Old Jul 24, 2004 | 08:35 AM
turboda6's Avatar
Default Re: (Turbo E 604)
you'll be fine..... my friend has a turbo hatch, jus to create a lil leak in it he only used 2 bolts to hold the turbo to the manifold thus creating exhaust leak b4 the turbo creating zero boost. he ran like this for like a year jus cuz he liked the sound of the turbo spooling out the down pipe. take off that accuater leave all ur piping and listen to it you'll be in love and it'll work fine.
si0385.
Oct 16, 2006 06:32 PM
JayDiem_k20_Dc5
May 28, 2006 09:13 AM
MiMiK
Dec 10, 2005 06:21 PM
XIntegraX
Jan 16, 2003 09:36 AM
seanjohn81
Sep 12, 2002 10:57 AM
