Running without intercooler
Old Aug 7, 2002 | 05:04 PM
legendboy's Avatar
Default Running without intercooler
Since I have everything done I just don't have an intercooler yet, well I have one but its still in my friends 944, can't I drive at low boost like 3 or 4 psi with out it?
Old Aug 7, 2002 | 05:09 PM
Cramerox's Avatar
Default Re: Running without intercooler (legendboy)
you can drive with no boost? but it will be tempting....im sure its safe but ur risking it.
Old Aug 7, 2002 | 06:21 PM
TheIntegraGuy's Avatar
Default Re: Running without intercooler (Cramerox)
You can drive without an IC but just stay out of boost as much as you can. It's probably going to cause some damage to the turbo over time w/o an IC.....but make sure you get one asap...
Old Aug 7, 2002 | 06:32 PM
Reid's Avatar
Global Moderator
Default Re: Running without intercooler (J-MiGiRL702)
What are you talking about?
You can run without an intercooler for as long as you please.
You won't damage anything.
Only difference is the air your motor is ingesting won't be as cold.
Old Aug 7, 2002 | 06:50 PM
Etylorcen's Avatar
Default Re: Running without intercooler (Reid)
You are more prone to detonation with hot air tho.
Old Aug 7, 2002 | 07:05 PM
Cramerox's Avatar
of course you can drive around without an IC....but is it good for your car? prolly not. why even try to risk it?
Edit: your so close to reaching boost why create future delays with busted ring lands.
[Modified by Cramerox, 8:09 PM 8/7/2002]
Old Aug 8, 2002 | 02:06 AM
Extent's Avatar
running w/o an intercooler shouldn't damage the turbo at all considering that all it does is cool the air before it reaches the engine
Old Aug 8, 2002 | 03:17 AM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
ran my Zcar with NO IC for two years untill got an IC, 7PSI on 9.0:1 CR, stock L28 with has MUCH lower anti-detonation properties.
91glassycrx
May 7, 2004 12:26 PM
Arsenal
Oct 13, 2003 06:55 AM
B-Series Sol
Jun 26, 2002 09:09 PM
Duck Sauce
Nov 26, 2001 02:43 PM
Arturbo
Nov 17, 2001 05:15 AM
