running super lean and need help!!! b18b turbo
Have the revhard stageII kit and it came with a new 255lph pump and some other ****. THe only thing is, when I hit throttle full 100% I run super lean. (its from both the apexi turbo timer a/f ratio and the gauge which i know are two shitty reading but its going INSANE lean aroudn 20:1 lean!!!!) But, when i go like 50-80% throttle, its around 14.9 the whole time which is better I guess. NOw it onloy has a apexi AVCR. Can I do anything about it without buying anything??? Or what is cheap to buy?
Eddie
Eddie
Give us a better discription of your fuel and ignition setup if you want better advice on what to do.
I've only seen a few people having problems with running rich after putting on that kit and 90% of the time it has to do with ignition. Not enough/strong enough spark for all of that fuel that you're putting into the motor.
What is your ignition setup??
Ignition is stock ofcourse. Well, today, for some reason, the car died while i was coming to a stop. the avcr reads that the TPS sensor is weak when the motor is on. I will press the gas and it will register as 0% throttle all the way to about 60% and then turn on. If i blip the gas hard it w9ill read really really low. Due to this, the car after revving begins to die some and then will pick back up. This happen after i hit a big *** pot hole. Someone wanna help me out with this, its pretty freakin important to me?
BoostedB16EF8
Jan 26, 2004 03:52 PM
Burke
Jul 24, 2003 01:14 PM
