Running rough... Need some ideas/help
Old Apr 15, 2004 | 12:15 PM
Dublocivic's Avatar
Default Running rough... Need some ideas/help
I posted in the hybrid forum about this and I got no response.. I put together a swap for a buddy of mine that consists of a obd0 b16a into an 92 cx. I have everything wired properly (obd1 distributer, injectors, engine harness, and a p30) with no codes. It idles a little rough but not to bad. I checked timing and its dead nuts on the cam and crank. When I advance the distributer (pushing it backward) it cleans it up a little but still wont rev smooth.. when It is set in the middle the motor bogs and wont rev..
Any ideas would be appreciated Thanks!
Old Apr 15, 2004 | 12:17 PM
G
sh!t happens.
Default Re: Running rough... Need some ideas/help (Dublocivic)
u sure there is no cel's how the plugs and plug wire and dizzy look? whats ur fuel pressure?
Old Apr 15, 2004 | 12:23 PM
Dublocivic's Avatar
Default Re: Running rough... Need some ideas/help (G"UNIT)
Well I swapped out the plugs and wires from my car which runs fine. The cap has a slight crack on the coil but Ive seen worse run better..lol I got the **** shocked out of me just a few mins ago while adjusting the timing. I also tried my distributer on it and it sounded the same.
The plugs looked rich. The car revs like the map is semi not seeing vac but it is secure with no leaks.
Old Apr 15, 2004 | 02:47 PM
Dublocivic's Avatar
bump
Anyone?
Old Apr 16, 2004 | 11:19 AM
pornstarSR's Avatar
what kind of spark plugs are in it?
maker not version
redmondracing
Oct 31, 2012 12:14 PM
averyvm
10
Jun 16, 2010 02:41 PM
srt4pilot
33
Jun 22, 2009 09:36 PM
extrmeboost
Dec 30, 2005 07:43 AM
RA062424
Dec 3, 2005 03:48 PM
