running riche
Old Mar 6, 2006 | 09:16 AM
spoolinegsr's Avatar
Default running rich
i have done some research already, but havent come up with any answers. i have a turbo gsr eg coupe, and it is running very rich. its at 12psi stock internals. should i get a block gaurd, lower comp head gasket, and arp bolts to run a little more boost, or what. i cant afford to build the motor yet, but it has 550cc injectors. should i just get smaller injectors until i can afford a motor build? im also needing a few other things, so all my money cant go into the motor, but i have about 300-400 for it.....
Old Mar 6, 2006 | 09:26 AM
adseguy's Avatar
Default Re: running rich (bluet1z06)
what's your fuel/ignition managment right now?
Old Mar 6, 2006 | 09:30 AM
themorphious's Avatar
Default Re: running rich (adseguy)
lol...build my engine to fix running rich.......hmm.....
Old Mar 6, 2006 | 09:35 AM
greddy emanage. i think its not running enough boost to support the injectors. its as 12lbs now
Old Mar 6, 2006 | 09:58 AM
adseguy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluet1z06 &raquo;</TD></TR><TR><TD CLASS="quote">greddy emanage. i think its not running enough boost to support the injectors. its as 12lbs now</TD></TR></TABLE>
If you knew how that system or any other tuning system worked you would know that turning up the boost will not solve your problem and is very dangerous. If you have injectors that are bigger then what was made for the e-manage then of course it'll run rich. Get a tune and problem solved .
Freshdot
Apr 12, 2011 02:50 PM
bboyjimpy
Sep 20, 2010 06:58 AM
mnlude
Oct 21, 2005 04:59 AM
mkinpwrat12g's
Sep 21, 2005 04:37 PM
r7
Jul 13, 2003 02:17 PM
