b16a2, 390 cc injectors 8 psi
ok well during a street tune, my car's power gave out and for some reason i dont have any power anymore. after the street tune the tuner says that my injectors are maxed out. keep in mind that i am only running 4 psi at this moment with no boost controller. right now im running lean as *** when i accelerate ( car is barely accelerating) and im not hitting boost cause im running so lean. does this sound right to anybody? i heard i can run 390cc on 8psi and get 240 whp.
Re: b16a2, 390 cc injectors 8 psi
why in the world would you use 390cc injectors on a boosted motor? your problem will always be not getting enough fuel, and its better to have more fuel than you need than not enough. how do you even run 4psi without a boost controller? i didnt think 4lb springs were made. you definetly need bigger injectors, and i wouldnt drive the car again with the ones you have now, unless you take the turbo kit off.
jamesfawcett
04-13-2010 01:33 AM
turbo*s2k
02-25-2004 11:50 AM
ZygSpeed
01-02-2002 09:44 AM
