running rich-need help
Old Mar 14, 2002 | 09:51 AM
td04civic's Avatar
Default running rich-need help
i have a 93 civic w/ the D16Z6 motor and the greddy kit. I'm running 8 psi of boost and under boost i tend to run rich. My fuel system is only the greddy blue box and a walbro 255lph intank fuel pump.
Can I buy an adjustable fuel pressure regualtor and lower the fuel pressure when i run at the tracks to lean out the fuel alittle? Or is it the injectors that needs controlling w/ something like an AFC? Thanks for your help.
Troy
Old Mar 14, 2002 | 09:59 AM
VTC_CiViC's Avatar
Default Re: running rich-need help (td04civic)
Use can turn down the pressure a bit with am adjustable regulator the likes of AEM, but this is if your pressure is already too high. Get yourself a pressure gauge and ensure the pressure is at stock, the Walbro may have bumped it sligthly.
Old Mar 14, 2002 | 10:01 AM
td04civic's Avatar
Default Re: running rich-need help (VTC_CiViC)
ok thanks alot. I'll pick up a guage.
Old Mar 14, 2002 | 10:36 AM
boost killz's Avatar
New User
Yeah definitely get a gauge, the addition of the walbro on my car increased pressure about almost 8 psi at idle.
Nick
Old Mar 14, 2002 | 10:40 AM
speshuled619's Avatar
Default Re: running rich-need help (boost killz)
hey guys how would calibrate a fuel guage? at idle what should the guage read with a fuel pump and reg? dont mean to intrde on this guys thread but its basically te same question and im just trying to open the window up a little more..
Old Mar 14, 2002 | 11:15 AM
td04civic's Avatar
so basically get a guage and if it's too high get a adjustable FPR and turn down the pressure back down to stock?
Thanks
Old Mar 14, 2002 | 01:24 PM
ATurboCivic2NV's Avatar
how do you know you are running rich? carbon build up or an A/F ratio gauge? also did you remove you cat. if you did that is one reason why!!
Old Mar 15, 2002 | 04:28 AM
td04civic's Avatar
Default Re: running rich-need help (ATurboCivic2NV)
i have an A/F guage. My stock cat is still in place. I checked the pressure w/ a b&m guage and it read 48psi. It's supposed to be between 31-36 stock.
Old Mar 15, 2002 | 02:26 PM
JFK78's Avatar
I am running the same setup as you but I have a straight pipe (no cat).
When I installed the 255lph pump my fuel pressure went from 42psi to 50psi at idle. I use a b&m commandflo, but I couldn't turn the pressure down with the new pump, so I drilled a relief hole in the FPR, and now I can turn it down to like 30psi if I want to.
On the dyno at 5.5 psi and 42 psi fuel pressure at idle, my a/f ratio was 12.5:1 across the board. I would run a little richer to be safe if I were you.
Since you still use the stock cat, I think that 38-40 psi should give you a nice safe a/f ratio.
Old Mar 17, 2002 | 12:05 PM
td04civic's Avatar
Default Re: running rich-need help (JFK78)
ok i adjusted the Fuel pressure w/ a AEM FPR to 32psi and it's still running rich under boost. On the autometer a/f guage it's all the way to the last bar in rich under boost. Should i lower the fuel pressure alittle more? I figure it's really low already. Any help would be appreciated. Thanks for the replys so far.
Troy
GsrIntegra789
Jun 4, 2008 04:00 PM
BoOsTeD C1
Jun 23, 2005 12:54 PM
portenio78
Jun 7, 2005 10:24 AM
s1ngle
Apr 14, 2005 12:14 PM
