running pig rich on new build!!!?
Old 08-02-2009, 08:18 AM
thegatekeeper14's Avatar
Default running pig rich on new build!!!?
ok well heres the set up
in a 92 da (DB2)
b20 sleeved
8.9:1 weisco's
eagle rods
b16 head with type r cams
e85
gm 3 bar map
dsm 950cc with resistor box
running crome
now when i start it it WILL NOT run with out some throttle open. the second it closes it dies out. there is tons of un used fuel in my exhaust,
the car shakes bunch. i went to my tuner and had 25% fuel take outta the base map. still same resaults. theres fuel on the pistons as well.
any imput will be appriciated.
ium sitting here in our shop. just waiting for advice...
thanks a bunch!
Old 08-02-2009, 09:21 AM
Default Re: running pig rich on new build!!!?
no ideas?
Old 08-02-2009, 09:30 AM
AJxr's Avatar
is there a such thing as dsm 950cc or is that a typo?
sounds like its surely tune related, shot injector, crazy fuel pressure. i had a similar problem with this when my map wasnt set for the correct map sensor i was using.
Old 08-02-2009, 09:36 AM
thats what i was thinking but now im just so lost and dunno where to start
Old 08-02-2009, 09:50 AM
my map should be fine this is the second base map
Old 08-02-2009, 11:00 AM
cjordan's Avatar
im assuming your tuner is doing your base maps, what are his thoughts? i have never heard of 950cc DSM injectors... injector stuck open maybe??
Old 08-02-2009, 11:20 AM
NLR808's Avatar
What throttle body are you useing?
Old 08-02-2009, 11:28 AM
type r throttle
Old 08-02-2009, 11:29 AM
wellthe big issue here is to much fuel... to rich, andf violnt shakes
Old 08-02-2009, 11:43 AM
kevdix's Avatar
hmm im running a very similar motor in my car, b20 sleeved same pistons/rods, b16 head, 1000cc injectors. I had the issue with the car bucking/shaking violently under 2500rpm in 1st/2nd gear. Just had my tuner adjust the a/f ratio in that range.
What I am very curious about is my car needs gas on the initial start up as well for about 30 seconds then it will idle fine. It is driving me crazy too so if anyone has some input I could use it as well.
Old 08-02-2009, 11:47 AM
Adam_b16a's Avatar
does it sound like its misfiring?
Old 08-02-2009, 11:55 AM
yeah seems like a mis fire
Old 08-02-2009, 12:24 PM
cjordan's Avatar
whats base timing set at?
Old 08-02-2009, 12:29 PM
tdc, dizzy is center
Old 08-02-2009, 01:39 PM
accord_raffi's Avatar
Test your injectors
Old 08-02-2009, 01:52 PM
moderator emeritus
98vtec's Avatar
basemaps.....
Old 08-02-2009, 02:17 PM
yea im thinking that too. my gf was pulling plug wires as i was tring to keep an idle. and no real change in the running conditions, so ill just have my tuner come up and run thrue it!
Old 08-02-2009, 02:20 PM
AJxr's Avatar
did you hit it with a timing light? are all cylinders getting spark? was the distributor wiring touched at all? injector plugs swapped at all?
Old 08-02-2009, 02:58 PM
yeah, i repined a obd 2 dizzy i did each wire one by one though.
Old 08-02-2009, 03:09 PM
BoostFedDB8's Avatar
If you are using crome and if they are really 950cc dsm injectors which I've never heard of before, try taking that injectors size and multiply it by .60 and input that as ur new injector size. then apply fuel tools in crome into ur rom and increase slowly til it idles fine. this should make ur cranking easier also. good luck
Old 08-02-2009, 04:58 PM
AJxr's Avatar
id go over those first, i had the same prob also when i wired up my obd1 distributor in my obd0 car.
Old 08-02-2009, 05:42 PM
huh
Old 08-02-2009, 06:18 PM
AJxr's Avatar
your distributor wiring, there could be a bad connection.
Old 08-02-2009, 08:37 PM
LightningTeg's Avatar
Get a wideband and have it actually tuned instead of the basemap.
Old 08-03-2009, 12:17 PM
^yeah hes comming out today
Quick Reply: running pig rich on new build!!!?
