backfiring ?
Old May 13, 2003 | 01:58 PM
spoon063's Avatar
Default backfiring ?
just put a drag 3 kit on and the last thing i need is spark plugs.. would the plugs be the cause of backfiring when shifting ?
Old May 13, 2003 | 02:01 PM
Canuk_SiR's Avatar
Default Re: backfiring ? (spoon063)
what kind of fuel management are you using? You're probably clogging the cylinders with fuel between shifts. does it also backfire when you rev the engine?
Old May 13, 2003 | 02:03 PM
spoon063's Avatar
Default Re: backfiring ? (Canuk_SiR)
i dont think its backfiring when i rev, i have in-tank fuel pump, stock injectors, aem fuel pressure regulator, fmu... to be honest i think i'm running rich, my a/f gauge wont work for ****
Old May 13, 2003 | 02:11 PM
PrecisionH23a's Avatar
Backfiring is a result from running rich. This "backfire" you are talking about, is it a KAPOWWW from your exhaust in between shifts or a "VAAVAAVAA" hesitation sound while under boost? If its the vaavaavaa hesitation (i know im technical) your gap is most likely off. Gap them to .030-.032 and get NGK-BRK7e-11's.
Old May 13, 2003 | 02:25 PM
spoon063's Avatar
Default Re: backfiring ? (GudeH23a)
i ordered ngk's and i know for a fact i'm runnign rich, i can smell it in the exhaust fumes, it runs a little wierd while acceleerating (kinda jerks until boost kicks in) then pops when i sift out the exhaust
Old May 13, 2003 | 02:52 PM
Jdm93civic's Avatar
running rich....................
Old May 13, 2003 | 03:05 PM
spoon063's Avatar
Default Re: backfiring ? (Jdm93civic)
thaaaaaaaaaaank you
98lude-t
Mar 28, 2004 09:33 AM
Ricey McRicerton
Oct 1, 2003 08:05 PM
sneakypete
May 29, 2003 02:35 PM
1.8T_EG
Oct 27, 2002 07:11 AM
