Running a hard oil feed?
Old Aug 10, 2006 | 10:39 PM
ghettocrxsi's Avatar
Default Running a hard oil feed?
I wanted to run a hard line to feed my new set up. Has anyone ever ran an ss like 1/8th-1/4" line and flare it out and put a fitting on? Thanks a lot.
Old Aug 10, 2006 | 11:41 PM
playahwitgame's Avatar
Default Re: Running a hard oil feed? (ghettocrxsi)
people including myself usually run an AN line. stealthmode performance has a good oil line kit. it consits of a block fitting which is bspt so it will screw in your block and not mess up the threads. then it omes with a 1/8npt to 3AN adapter and the 3 AN line. also comes with the fitting that goes in the turbo. also a 1/8-3 AN
Old Aug 11, 2006 | 12:53 AM
pgmatt's Avatar
Yes I have and it worked fine.
Old Aug 11, 2006 | 12:05 PM
Default Re: Running a hard oil feed? (pgmatt)
I had an oil line kit from stan at fast turbo, but my kit got stolen off my car and they cut the -3an line. So I wanted to replace it with a hard line and run it around the block. What size do pepole usually use?
Old Aug 11, 2006 | 01:27 PM
pgmatt's Avatar
1/8 or 1/4+ with a restrictor.
Old Aug 11, 2006 | 08:25 PM
nfn15037's Avatar
Hard lines work fine. Use a flare nut and double flare the tubing. I had a stainless braided line fail internally near the turbo and start a giant oil fire during a rally. Never again with hard line.
Old Aug 11, 2006 | 09:34 PM
Default Re: Running a hard oil feed? (nfn15037)
Thanks guys I will go buy some 1/8th in this weekend and finish my car up.
FWD_BEAST
Mar 2, 2015 08:31 AM
gooberguy31
Feb 25, 2009 12:09 PM
Casey
Aug 13, 2004 09:10 PM
beepy
Mar 1, 2004 09:26 PM
Del_Slowest
Nov 27, 2003 09:07 AM
