Runaway H22
Old Jul 29, 2008 | 01:37 PM
purpleh22's Avatar
Default Runaway H22
Just changed from a GT30 w .82 exh., to a GT35 w .82. The 44 Tial seemed to handle the GT30 just fine. Switched out turbos with everything else the same and the GT35 seems to overpower the Tial 44. The spring should hold it to around 10 lbs. but @ 7K rpms boost touches 18.5 lbs. I notice that other setups seem to do OK with 44 or smaller Tials. On other postings I've seen comments about it possibly being aggravated by odd wastegate installations. My setup is pretty much the normal straight forward looking type. I'm thinking of changing to a Tial 60.
Any feedback?
Built H22, Darton sleeves, Crower rods, Arias 10:1 pistons, Prodrive oil pump gears, stock cams, GE intake, Revhard exh., MSD digital 6, GT35, Spec Stage 3+ clutch, 70mm TB, SBC electronic boost cont. etc. etc.
E85, 505 whp, 383 wtq @7000 & 18.5 lbs when shut down due to boost climbing.
Old Jul 29, 2008 | 01:45 PM
Bseriescivic5's Avatar
nothing stupid like loose bolts, blown gaskett, some little leak at the waste, gate, vacume source, Crack in manifold?
Old Jul 29, 2008 | 02:51 PM
purpleh22's Avatar
Default Re: (Bseriescivic5)
No problems were experienced with the previous GT3082 installation but I had similar problems with the same setup when initially using a SC61 prior to the GT30. That problem was the reason I changed to the GT30.
Old Jul 29, 2008 | 05:32 PM
interesting, im stumped atm....
street_ride14
Oct 10, 2009 03:32 PM
jdm knight
Mar 15, 2008 06:05 AM
Cyberdx16
Oct 18, 2006 09:07 PM
gooseman
Jun 23, 2006 01:26 PM
purpleh22
Jan 12, 2006 04:36 PM
