ruff idling... sounds bad in the low RPM.. HELP
This is a b18b turbo setup.. with 450 injector, S-AFC
This engine a JE Pro Series 9.2:1 CR Forged Pistons
This is the situation,
When it's idling, it sounds rough. bouncing a little.
When it run in low RPM, it's "knocking"
I checked the spark plug, it's extremely dark (too rich)
I also did a compression test
~150
~140
~120
~160
My mechanic told me, there is something wrong with this engine... it's knocking. Now I am not sure what knocking sounds like, but the engine sounds like ****. If the engine is really knocking, what can be going wrong here?
~150
~140
~120
~160
Re: ruff idling... sounds bad in the low RPM.. HELP (chusai)
Well bro,
I hate to say it but i beleive your motor is cashed, if your mechanic says it is knocking, and he is a trust worthy guy, i would trust him.
Also by looking at your Comp. #'s you have a problem in the cylinder with only 120Psi.
I think it is time to tear the motor apart before it gets any worse.
A rough idle can be caused by the large injectors also, and sometimes you can remedy this by turning the idle up just a bit.
HTH
Brian
HTH
Brian
Any check engine lights?
Looks like the cylinder with 120 psi isn't too good.
Any knocking is bad, really bad.
Next step is do a leak down and see what that shows.
Is this a new engine? Was it running fine before? What mods did you do to it before it started to go bad?
Re: ruff idling... sounds bad in the low RPM.. HELP (ekb18c)
ok, I just bought this car, the engine came with it. I called the seller and ask him about the 120 psi, and he said it's due to the JE piston.
and the ruff idling is due to the broke tranny.. however when I was testing this, I had the clutch press in - disengaged the engine with the tranny.. I really doubt it's the tranny.
can the ruff idling and knocking be the result of bad tuning?
the problem is.. I have a mechanic do this for me.. if I have to take the engine apart.. it's gonna cost me lots of money
[Modified by chusai, 10:23 AM 3/28/2003]
120 psi is too low compared to the rest of the cylinders. They should be pretty much even all across the board but since one is off track then that cyinder is going bad.
Idle has nothign to do with the tranny.
Rough idling and knocking could be a result of bad tuning.
I would get some money from the seller because he sold you a motor that is on it's way out, or it wouldn't perform as it shoudl be because the comrpession numbers don;t match. Ask your guy to do a leakdown test....
HTH
HTH
HELLO,GOOD MORNIN'
Just to give you an idea. I have the same compression as you and mine is 150 all the way across. You have a few problems. A good rule of thumb. if the numbers are very close then your cool. If you have numbers that aren't consistant you have a problem that needs to be investigated.
Colin... once I get the car running(the car doesnt have a tranny now), I will make an appointment to have you guys look at the car (should be sometime next week)...
the seller also claimed that a compression ratio is not accurate on JE pistons? I should do a leak down test instead, is that true?
[Modified by chusai, 10:52 AM 3/28/2003]
Give us a call when you get it up and running and we'll fix it for you.
I would think compression wouldnt affect the idle unless its under 100psi.
Sounds to me like those 450s arent tuned right. The knocking noise could be a spun rod bearing.
Re: ruff idling... sounds bad in the low RPM.. HELP (BoostedSi)
that's exactly my guess.. but with that 120.... I have to agree with Colin, it's probably on it way out sooner or later
