RSX Boosting problem. Help????!!!!
Old Feb 23, 2005 | 04:00 PM
vtecpowerd's Avatar
Default RSX Boosting problem. Help????!!!!
Ok to describe the problem:
1. In neutral revs cut off at 5 Grand
2. When driving boost is sluggish (more than normal)
3. Boosts at half throttle, but full throttle bogs down hard.
4. looks like runs really lean, maybe because lots of fuel and no boosting?
5. Boost feels like it starts dieing at 6 grand.
Anyone ever have similar problems.[b]
post up possible fixes.
ps: map sensor isnt hooked up. thats the only problem found so far, could this cause all these symptoms.[b]
Old Feb 23, 2005 | 04:12 PM
SOHC_MShue's Avatar
Default Re: RSX Boosting problem. Help????!!!! (vtecpowerd)
umm yea....the map sensor is kinda important
Old Feb 23, 2005 | 04:39 PM
warrick's Avatar
Default Re: RSX Boosting problem. Help????!!!! (SOHC_MShue)
errr..... you don't run lean when you have too much fuel. you need that map sensor hooked up.
what are you using for fuel management?
Old Feb 23, 2005 | 04:51 PM
Muckman's Avatar
Moderator in Chief
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">umm yea....the map sensor is kinda important</TD></TR></TABLE>
lol this is a funny thread.
MAP = Manifold Absolute Pressure. Its very critical to measure the amount of air coming into the engine to add the proper amount of fuel.
Old Feb 23, 2005 | 05:20 PM
vtecpowerd's Avatar
Map sensor will be in and will this fix some of the problems.
The car is running off of Greddy emanage.
PS: Car was not hooked up by me, or anyone i know, Just trying to fix probles.
PSS: car isnt mine.
Old Feb 23, 2005 | 05:21 PM
vtecpowerd's Avatar
Anyone else?
Old Feb 23, 2005 | 05:44 PM
Rocks
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecpowerd &raquo;</TD></TR><TR><TD CLASS="quote">
Cough Bingo Cough
This is very very very very important. How could you not hook this up.
Old Feb 23, 2005 | 05:48 PM
beepy's Avatar
Lol. That's like saying, "I have this oil leak I can't track down. The only thing I know is there is no oil pan installed yet."
Here's your sign.
Old Feb 23, 2005 | 06:37 PM
vtecpowerd's Avatar
I dont know, probly because the last guy that owned the car was a dumbass. but back on topic.. Help.
Old Feb 23, 2005 | 06:39 PM
Rocks
Guest
Posts: n/a
Default Re: (vtecpowerd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecpowerd &raquo;</TD></TR><TR><TD CLASS="quote">I dont know, probly because the last guy that owned the car was a dumbass. but back on topic.. Help.</TD></TR></TABLE>
listen to what we say were professionals. :shakes head: hahaha
Old Feb 23, 2005 | 06:54 PM
beepy's Avatar
Ahem..
<U>HOOK THE MAP SENSOR UP!!!!!!!!!!!!!!!!!!!!!!</U>
Old Feb 23, 2005 | 06:57 PM
Rocks
Guest
Posts: n/a
you shouldnt be boosting cars if you drive around with the map sensor not hooked up! Im pretty sure it will be blown in a week or so if you let little problems like this screw you up. DId I say a little problem a huge problem dude.
Old Feb 23, 2005 | 07:19 PM
TUR3Ovtec's Avatar
Default Re: RSX Boosting problem. Help????!!!! (Rocks)
what kind of injector's do you have? i had the same problem but its most likely either that map sensor, or you injector's i had mines redone by DRAGLS here on HT and it all stopped!
Old Feb 23, 2005 | 07:52 PM
vtecpowerd's Avatar
I dont know what he has, Im assuming the injectors that came with the greddy Turbo kit.
And map sensor will be hooked up tomorow.
Ps: again cars not mine lol. Just looked at the car yesterday, we didnt deal with the kit, previous owner did.
Old Feb 24, 2005 | 08:40 AM
vtecpowerd's Avatar
Bump/ help
Old Feb 24, 2005 | 08:42 AM
Civicman86's Avatar
ROFL that is sig worthy
Old Feb 24, 2005 | 06:35 PM
vtecpowerd's Avatar
I dont belive i ever said it wasnt important, I knew this. Hence its being fixed. Do you all ahve anye USEFULL information. And AGAIN, Not my fault or anyones fault for the problem. Not my fault. Im not a dumbass.
I dont own the car, hence the sig. I have A TYPE R. Youall try to flame for stupid ****.
Old Feb 24, 2005 | 06:55 PM
JDM.Accord's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecpowerd &raquo;</TD></TR><TR><TD CLASS="quote">I dont belive i ever said it wasnt important, I knew this. Hence its being fixed. Do you all ahve anye USEFULL information. And AGAIN, Not my fault or anyones fault for the problem. Not my fault. Im not a dumbass.
I dont own the car, hence the sig. I have A TYPE R. Youall try to flame for stupid ****. </TD></TR></TABLE>
Dude, nobody's flaming. And I believe that telling you to hook up the MAP sensor would qualify as useful information Until you do that you're not gonna get any answers as to what else could potentially be a problem.
Old Feb 25, 2005 | 07:30 AM
vtecpowerd's Avatar
Ok your right, some are just being smart asses. Its hooked up now and were gona take it out, ill letyouall know any other problems a little later today.
Old Mar 4, 2005 | 11:16 AM
Muckman's Avatar
Moderator in Chief
From the lack of a follow up I take it the MAP sensor solved all your problems?
Old Mar 4, 2005 | 01:57 PM
Rtype16's Avatar
Default Re: (Muckman)
The RSX does this no matter if is turbo or not. If the vehicle is not moving it has a rev limit of 5 grand. Don't worry about that.
Install the map sensor and tune the car.
Get my jist on the answers for your questions you definately need the map sensor to make any car run correctly. Most of you problems are due to the fact you don't have the map sensor installed and have the car properly tuned.
Blue94Accord
May 14, 2010 06:46 PM
hybridracer504
Mar 25, 2009 09:01 PM
ATS*Mark
33
May 1, 2006 07:42 PM
Dr Pooface
Nov 19, 2005 12:37 PM
agratise
Feb 24, 2005 05:48 AM
