RPM Service 72mm T/B issues....anyone else
well on the new motor build i swapped out my bored our GSR throttle body for an RPM Service 72mm. Now after, i got the started the car has a horrible fluctuation in idle.
it idles from like 1000-1600, almost sounds like an IACV issue, but i get no CELs, at all.
i checked for vacuum leaks, i pressurized the intercooler piping and intake manifold with 50psi of air and i have no vacuum leaks at all.
im going to do a valve adjustment on the car since the motor is broke in because i believe my valvetrain is a bit too tight
also this RPM T/Body has no FITV on the bottom, if that makes a difference
and this is the model im using just in 72MM
Re: RPM Service 72mm T/B issues....anyone else (mrbsponge)
Make sure you have the right gasket and that the TPS is set correctly. If you have the gasket for the t/b with the fitv, i don't think it'll seal right on that t/b.
i had the same problem with the 70mm tb.. the TPS voltage was wayy off.. after fiddling around with the TPS sensor i got a much better idle
Re: RPM Service 72mm T/B issues....anyone else (atec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 »</TD></TR><TR><TD CLASS="quote">Make sure you have the right gasket and that the TPS is set correctly. If you have the gasket for the t/b with the fitv, i don't think it'll seal right on that t/b.</TD></TR></TABLE>
what gasket can you use on something like that tony? i was thinking of either making one, or just using some liquid gasket maker, as ghetto as that sounds! im using the "outlaw engineering" thermal gasket, and it seems to cover enough, even tho i had to trim the inside out, to almost nothing
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Peter Shen »</TD></TR><TR><TD CLASS="quote">i had the same problem with the 70mm tb.. the TPS voltage was wayy off.. after fiddling around with the TPS sensor i got a much better idle </TD></TR></TABLE>
i will check that when i get home from work tonight, good call, i wasnt even thinking of that. just started the new motor up for the first time and was trying to just get her to warm up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by atec »</TD></TR><TR><TD CLASS="quote">2 of 2 our builds with that throttlebody have problems with idle.
Now the TB shaft (inside TB) broke.
WOW that isnt even cool, how did something like that happen?
Re: RPM Service 72mm T/B issues....anyone else (vaporboy12)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vaporboy12 »</TD></TR><TR><TD CLASS="quote">i just used honda bond for a gasket there</TD></TR></TABLE>
thats kinda what i was thinking
Re: RPM Service 72mm T/B issues....anyone else (Blue Streak)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blue Streak »</TD></TR><TR><TD CLASS="quote">does anyone have there phone #</TD></TR></TABLE>
i just looked, and cant find it either
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Casey »</TD></TR><TR><TD CLASS="quote">bump hope you get it figured out. i do remember howard taking a few minutes to get my car to idle correctly with it.</TD></TR></TABLE>
howard who?, maybe he can shed some light on me
Re: RPM Service 72mm T/B issues....anyone else (Casey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Casey »</TD></TR><TR><TD CLASS="quote">shoaf...airshifter on here, works at rlz/speed innovations</TD></TR></TABLE>
thanks.
thanks.
well im running one of their 68mm tb on my sohc and it i'm having the same idle problem. im going to switch to another one, it sucks
EDIT: Problem fixed!
my dumb fault, when i trimmed the gasket to fit the T/B, i accidentally trimmed too far and got into the IACV and FITV air passages.
idles fine now
idles fine now
