rotating turbo outlet
Old Aug 9, 2003 | 09:54 AM
PHiZ's Avatar
Default rotating turbo outlet
My turbo was rebuilt before I got it, but the compressor is 90 degrees to the manifold flange, so the compressor smacks directly into the engine block. Can this piece be rotated like 30 degrees downwards... Does a professional shop have to do it?
-PHiZ
Modified by PHiZ at 2:09 PM 8/9/2003
Old Aug 9, 2003 | 10:02 AM
NateTEG95's Avatar
Default Re: rotating turbo outlet (PHiZ)
Get a 13mm wrench and loosen the bolts around the housing (notice how I said loosen and not remove). You'll be able to rotate it pretty easily. This goes for both sides of the turbo (and the center section).
Old Aug 9, 2003 | 10:15 AM
PHiZ's Avatar
Default Re: rotating turbo outlet (NateTEG95)
Thanks, I see what you are talking about. Is there anyway someone can find the torque specs, that it should be re-tightened to?
-PHiZ
Old Aug 9, 2003 | 12:34 PM
NateTEG95's Avatar
Just tighten it with a wrench. They're not incredibly tight, and they don't need to be. There's some kind of washer in all of the bolts, right?
Old Aug 9, 2003 | 12:45 PM
Boostfed's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PHiZ &raquo;</TD></TR><TR><TD CLASS="quote">Thanks, I see what you are talking about. Is there anyway someone can find the torque specs, that it should be re-tightened to?
-PHiZ</TD></TR></TABLE>
As said before just tighten good. There are actually torque specs to them though, Garrett turboes come with a tag on them with warranty info and how to clock the turbo and the torque for the bolts and pre lube of the turbo etc etc. Looks like this, I didn't get mine with my new turbo though Geoff! ...................J/K
If you get a magnifying glass or somebodies Coke bottle glasses you may be able to read the instructions! LOL! Either Geoff, Art or the Cheapturbo.com guy can elaborate or help out.
Tippyman
Jun 1, 2007 02:53 PM
92b16si
Feb 16, 2006 09:01 PM
pro547
Jun 20, 2005 12:54 PM
youngkow
Jan 3, 2003 12:03 PM
jamal-188
Jul 6, 2002 06:24 PM
