ross cates custom manifold problems
Old May 30, 2005 | 02:48 PM
crxvtecturbo's Avatar
* B A N N E D *
Default ross cates custom manifold problems
i just got a couple problems fixed with my manifold the only problem i have left is the header flange is warped a 1/4 of a inch and the flange is .5 thick so if they take off a 1/4 inch that only leaves me witha a 1/4 inch is that going to be allright?Or shoud i cut slots inbetween the runners threw the bolt holes because that is what the machine shop said or what should i do [IMG][/IMG]
Modified by crxvtecturbo at 4:06 PM 5/30/2005
Old May 30, 2005 | 02:52 PM
Fab-Works's Avatar
Default Re: ross cates custom manifold problems (crxvtecturbo)
I would try to resurface it. It should be fine. Theres a good chance if you cut slots on the flange it will shift.
Old May 30, 2005 | 02:56 PM
* B A N N E D *
Default Re: ross cates custom manifold problems (anthonycn)
but if i have a .5 inch flange and i take 1/4 inch off that will only leave me with a 1/4 inch is that going to be enough left because that is less than 3/8
turtle-eg's Avatar
Try bolting it up to the head first without the turbo.... My manifold came that way too, I thought ups dropped it one too many times.... anyways I bolted it up to the head, and it was fine.
Old May 30, 2005 | 03:00 PM
* B A N N E D *
Default Re: ross cates custom manifold problems (turtle-eg)
i allready dropped it off at the machine shop
Old May 30, 2005 | 03:28 PM
* B A N N E D *
ttt
Old May 30, 2005 | 03:56 PM
Bailhatch's Avatar
wow thats really warped. I would cut the flange between the runners since it is obviously under stress. Then resurface it.
Old May 30, 2005 | 05:49 PM
* B A N N E D *
Default Re: ross cates custom manifold problems (Bailhatch)
Old May 31, 2005 | 07:08 AM
* B A N N E D *
Old May 31, 2005 | 03:53 PM
* B A N N E D *
Old May 31, 2005 | 05:29 PM
* B A N N E D *
Old May 31, 2005 | 05:53 PM
Dragline's Avatar
This boys retarded!!!!!!!!!
CreeWorks
Welding / Fabrication
Mar 30, 2010 01:30 PM
nitroice40
Apr 6, 2006 03:11 PM
RACEPAK
Jan 5, 2006 01:29 PM
crxvtecturbo
10
May 31, 2005 06:24 PM
Bailhatch
Jan 12, 2004 08:56 PM
