Rich and lean afr
Old Jul 16, 2012 | 02:22 PM
b17boosted's Avatar
Default Rich and lean afr
I have a boosted b17a1 with a t3/t4 57 trim its street tuned and it has a stage 3 yonaka clutch, Cometic gasket, all stock internals minus buddy club cam gears. When I got it tuned it had a ram horn manifold with a full 2.5 straight pipe. I recently just installed a 3" downpipe and it's straight back till the S bend an stops. When I have a warm idle the air fuel goes off the aem uego gauge no reading when cruising its a 14:5-15:6. When in boost to about .45 bars do 6.6psi the afr is 11:3 but anything after that it goes to 10:0. What do you think is the problem?
Also the head is ticking but I got my tuner to do a valve adjustment and it ran fine no ticking but now it's ticking again. Any ideas thanks!!
Old Jul 16, 2012 | 03:16 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: Rich and lean afr
off the reading high or low?
and the 3" downpipe and exhaust normally warrants a new tune...
it will cruise around that afr... part throttle low load requires very little fuel...
Old Jul 16, 2012 | 05:16 PM
b17boosted's Avatar
What do your an off the reading high and low? And ok that's fine I'll get a retune after I figure this ticking out.
Old Jul 16, 2012 | 05:22 PM
wantboost's Avatar
Who is Mr Robot?
at warm idle... does it swing high then go blank or swing low then go blank
Old Jul 16, 2012 | 05:44 PM
b17boosted's Avatar
On warm itll swing high to to blank to the lean side
Old Jul 16, 2012 | 06:59 PM
dpetro1's Avatar
sounds like you need to adjust the tune
Old Jul 17, 2012 | 02:59 AM
b17boosted's Avatar
Can I do that myself? Like am I able to adjust the a/f with a stock fpr
Old Jul 17, 2012 | 05:50 AM
rclark's Avatar
no.
Old Jul 17, 2012 | 08:03 AM
wantboost's Avatar
Who is Mr Robot?
that is all
2x0
Engine Management and Tuning
Feb 25, 2017 11:21 AM
EX-T
Mar 19, 2011 01:09 PM
crx88fast
May 3, 2005 08:53 PM
clsmooth
Feb 15, 2004 11:18 AM
Diego Boost
Dec 21, 2002 08:52 AM
