returnless fuel setup limitations
Old Jul 21, 2003 | 02:40 PM
k20em2's Avatar
Default returnless fuel setup limitations
I wanted to know if I would have to change from a returnless fuel setup if I eventually wanted to raise the boost. After I build up the internals, I plan to turn the boost up to 15 psi. Can a returnless fuel set up be good for only low boost or would I have to convert it. I'm using an aeromotive billet digital fmu. I heard I can still use this as long as I get bigger injectors.
Old Jul 21, 2003 | 02:41 PM
ion_four's Avatar
Default Re: returnless fuel setup limitations (k20em2)
If you "turn up the boost" use shouldn't use an FMU, so the point will be moot.
Old Jul 21, 2003 | 02:42 PM
Full-Race Geoff's Avatar
it really depends how much power you are trying to make. If you boost a little turbo to 15+ psi it wont be as dangerous as a 60-1 at that much boost.
What kit and what size turbo do you run?
i would actually say its worth considering that FMU system with some sort of a piggyback and you might be ok, the digital FMU is pretty interesting.
Old Jul 21, 2003 | 02:47 PM
k20em2's Avatar
Default Re: returnless fuel setup limitations (FFgeoff)
Its a custom setup using an sc34. What do I need to do then, to run more boost?
Old Jul 21, 2003 | 02:52 PM
you need to get a wideband on the car. I also definatley recommend running a j&s knock setup because your car has no control over timing
swpdb16
Oct 20, 2004 07:01 PM
gen4h22a
Aug 12, 2004 01:12 PM
99civicdx
Jun 27, 2002 02:27 PM
DLB1994
Apr 2, 2002 03:53 AM
