is a retune needed?
Old Aug 5, 2006 | 11:53 PM
playahwitgame's Avatar
Default is a retune needed?
i have 2.5 inch ic pipes all the way from the turbo -tb. well i got a leak in 1 of the shitty pipings so i was looking around and found a nice kit that is 2 inches from turbo to ic, then 2.5 from ic -tb. my question is if i replace the piping, is a retune needed?
and also while im on the topic, is a retune needed if i add a thermal intake manifold gaket?
by the way its a 2000 gsr turbo with hondata s200b
Old Aug 6, 2006 | 12:17 AM
komat's Avatar
Default Re: is a retune needed? (playahwitgame)
thermal intake gasket is a waste of money. it does jackshit....
as for retune iw ould recommend it if you tuned it with the leak. if you tune the car without a leak i woldnt bother for a new one
Old Aug 6, 2006 | 12:21 AM
Default Re: is a retune needed? (komat)
well i dont even know if it was leaking on the dyno, it seemed fine, i dont know, i have a wideband, ill look and see
Old Aug 6, 2006 | 08:15 AM
nickromeo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by komat &raquo;</TD></TR><TR><TD CLASS="quote">thermal intake gasket is a waste of money. it does jackshit....
as for retune iw ould recommend it if you tuned it with the leak. if you tune the car without a leak i woldnt bother for a new one</TD></TR></TABLE>
are u suere the thermal intake does nothing?
lots of people are running them including me,
Old Aug 6, 2006 | 10:55 AM
komat's Avatar
Default Re: is a retune needed? (nickromeo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nickromeo &raquo;</TD></TR><TR><TD CLASS="quote">
lots of people are running them including me,</TD></TR></TABLE>
i run one on my setup. the intake manifold is still as hot as before. it may of cool like 10F or something.
Old Aug 6, 2006 | 11:04 AM
TheThiefTheKnife'NTheGun's Avatar
i run one on my setup. the intake manifold is still as hot as before. it may of cool like 10F or something.</TD></TR></TABLE>
10 degrees less is better than nothing
Old Aug 6, 2006 | 11:06 AM
EK k kay's Avatar
Default Re: is a retune needed? (TheThiefTheKnife'NTheGun)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheThiefTheKnife’NTheGun &raquo;</TD></TR><TR><TD CLASS="quote">
10 degrees less is better than nothing</TD></TR></TABLE>
And it beats having to scrape the oem paper gasket off everytime you remove the manifold. Plus it's reusable. My thermal im gasket saved me tons of headaches because I had to pull my manifold off 4 times turing my turbo installation. Got my off-brand thermal gasket from spoolin performance for around $35.
Old Aug 6, 2006 | 11:19 AM
95GSRTT
Guest
Posts: n/a
Default Re: is a retune needed? (EK k kay)
ya I think its worth it just b/c you dont have to worry about that shitty oem paper like gasket.
Old Aug 6, 2006 | 12:52 PM
Default Re: is a retune needed? (95GSRTT)
but would u have to retune if oyu changed the gasket and the pipes to the 2 inch?
Old Aug 6, 2006 | 07:38 PM
It wouldnt hurt... Any time you change anything that has to do with air flow it will change your mixture
B-B-K
23
May 4, 2005 08:43 PM
fafsa
Feb 3, 2005 07:16 PM
EKB18BPR3
Jun 27, 2004 08:09 PM
r0cket247
36
May 26, 2004 10:16 AM
Tad
Dec 30, 2003 08:56 AM
