Resiter Box install????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE_Chris »</TD></TR><TR><TD CLASS="quote">Helpful LINK </TD></TR></TABLE>
This will help as well.
More Helpful LINKs
More Helpful LINKs
here's how i did mine...
mount the box somewhere easily accesible to the inj wiring.
remove the cable cover/sleeving/wire loom running to the injectors.
cut all the wires that are the same color running TO each injector, twist them together and attach to the 1 different wire on the resistor box.
run the remaining wires from the resistorbox that look identical to each other back TO the injector clip wire that was cut.
if you are installing new clips then do the same thing, but then cut the remaining wires that do not match one by one and run them to the new clips and install on the injectors.
enjoy.
enjoy.
booscivic
Oct 31, 2003 05:13 PM
