Resistor Box Wiring - This should work... Right?
Old Apr 30, 2006 | 05:38 PM
AbitAvenger's Avatar
Default Resistor Box Wiring - This should work... Right?
This is going to intercept the power going to the injectors, and then after being resisted ( ) then these go back to the injectors.
I just wanted to make sure that the piggyback system of wiring (pic 2) I have going into the resistor box is going to work fine. Thanks
Plug and play FTW
Old Apr 30, 2006 | 06:14 PM
ccivic's Avatar
Default Re: Resistor Box Wiring - This should work... Right? (AbitAvenger)
Yeah should work fine, although I recommend solder&heatshrink.
Old Apr 30, 2006 | 06:18 PM
vaporboy12's Avatar
Default Re: Resistor Box Wiring - This should work... Right? (ccivic)
yeah that **** looks like 20 times harder than wiring it should be
turboteg2nv's Avatar
^^But that wouldn't be plug and play anymore, now would it?
Where do you plan on mounting that thing?? Long enough wires?
Old Apr 30, 2006 | 06:31 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ccivic &raquo;</TD></TR><TR><TD CLASS="quote">Yeah should work fine, although I recommend solder&heatshrink.</TD></TR></TABLE>The setup on the box is still the same, those are old pics. New setup is heat shrink connectors which also have an adhesive inside
The wires have since been shortened also, and plug and play ownz j00 all.
Old Apr 30, 2006 | 08:36 PM
Emshhh's Avatar
there's "cleaner" way to do that :/
just use the dead-end clip.
check out my How to: turbo install for a better explaination of what is above..
https://honda-tech.com/zerothread?id=1263795
Old May 1, 2006 | 10:03 AM
Default Re: (iGfrequency)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iGfrequency &raquo;</TD></TR><TR><TD CLASS="quote">there's "cleaner" way to do that :/
https://honda-tech.com/zerothread?id=1263795</TD></TR></TABLE>I'd rather do it my way and know it works instead of testing all of the wires in the clip to make sure they'll work with the way my resistor box wires are setup. To each his own
turbosol18
Aug 12, 2007 07:49 PM
VTECJUN
Dec 13, 2005 11:44 AM
cornhusker
Sep 24, 2003 06:06 AM
hollaback6
Mar 24, 2003 10:34 AM
90_Civic_Hatch
Jun 13, 2002 09:00 AM
