Resistor Box Wiring - This should work... Right?
http://home.comcast.net/~abitavenger135/res.jpg http://home.comcast.net/~abitavenger135/res2.jpg
This is going to intercept the power going to the injectors,http://home.comcast.net/~abitavenger135/res3.jpg and then after being resisted ( https://honda-tech.com/forums/images/smilies/emwink.gif ) then these go back to the injectors. I just wanted to make sure that the piggyback system of wiring (pic 2) I have going into the resistor box is going to work fine. Thanks Plug and play FTW https://honda-tech.com/forums/images/smilies/emthup.gif |
Re: Resistor Box Wiring - This should work... Right? (AbitAvenger)
Yeah should work fine, although I recommend solder&heatshrink.
Re: Resistor Box Wiring - This should work... Right? (ccivic)
yeah that shit looks like 20 times harder than wiring it should be
^^But that wouldn't be plug and play anymore, now would it? https://honda-tech.com/forums/images/smilies/emwink.gif
Where do you plan on mounting that thing?? Long enough wires? |
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ccivic »</TD></TR><TR><TD CLASS="quote">Yeah should work fine, although I recommend solder&heatshrink.</TD></TR></TABLE>The setup on the box is still the same, those are old pics. New setup is heat shrink connectors which also have an adhesive inside https://honda-tech.com/forums/images/smilies/emwink.gif
The wires have since been shortened also, and plug and play ownz j00 all. |
there's "cleaner" way to do that :/
https://img.photobucket.com/albums/v...esistorbox.jpg just use the dead-end clip. https://img.photobucket.com/albums/v...eadendclip.jpg check out my How to: turbo install for a better explaination of what is above.. https://honda-tech.com/zerothread?id=1263795 |
Re: (iGfrequency)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iGfrequency »</TD></TR><TR><TD CLASS="quote">there's "cleaner" way to do that :/
https://img.photobucket.com/albums/v...esistorbox.jpg just use the dead-end clip. https://img.photobucket.com/albums/v...eadendclip.jpg check out my How to: turbo install for a better explaination of what is above.. https://honda-tech.com/zerothread?id=1263795</TD></TR></TABLE>I'd rather do it my way and know it works instead of testing all of the wires in the clip to make sure they'll work with the way my resistor box wires are setup. To each his own https://honda-tech.com/forums/images/smilies/emthup.gif |
