Resistor box wires...
Old 11-11-2009, 09:32 AM
SrVShayner's Avatar
Default Resistor box wires...
I've been looking at a whole bunch of sites to wire a resistor box and it says to use a multimeter on the wire to see what ones lead to the injectors.. problem is i never used one and dont know how to figure it out.
Can anyone help me on figuring out what 4 wires i have to find. its a 98 Integra GSR if that helps any? i know how to wire it all up after i find out what 4 to cut/splice.
Thanks
Old 11-11-2009, 10:05 AM
AutoSelectTuning's Avatar
Default Re: Resistor box wires...
You have to cut the yellow and black wire from each fuel injector. Then you wire in your resistor box in place of the wires that you cut and power up the resistor box from an ignition source.
Old 11-11-2009, 10:55 AM
jdm inc's Avatar
this might help
http://hondata.com/techinjectorwiring.html
here is another write up
https://honda-tech.com/forums/forced-induction-16/official-injector-resistor-box-install-56k-buy-broadband-517274/
Old 11-11-2009, 12:06 PM
SrVShayner's Avatar
i know how to wire it all up together but i dont know how to use the multimeter! where do u put the prongs at? im still trying to find out how to use a multimeter ..im not asking on how to wire it up.. im asking on how u can find what 4 wires i need using a multimeter
Old 11-11-2009, 12:32 PM
jdm inc's Avatar
u use the multimeter to check for continuity. You have to setup the multimeter to do that.
What kind of multimeter are you using?
Old 11-11-2009, 01:21 PM
lol. Cut wires and solder the box in. DONE!.
CPreston
02-11-2011 02:38 PM
soon2bdropped
12-03-2007 08:46 AM
vladd
08-04-2006 04:28 PM
Project92Hatch
02-16-2004 03:46 PM
importimage
10-31-2003 09:07 PM
Quick Reply: Resistor box wires...
