Resistor box question...did a search
Old Jul 12, 2004 | 10:36 AM
94greddycivic's Avatar
Default Resistor box question...did a search
ok i have a resistor box at my house and it still has all the connectors attached to it....can i just put the 440s in the car and plug in the resistor box(obd1) and call it a night or do i still have to cut wires....
all info will help
Old Jul 12, 2004 | 10:41 AM
ladysman's Avatar
Default Re: Resistor box question...did a search (94greddycivic)
Cut wires.
https://honda-tech.com/zerothread?id=517274
I think there was someone that used hte plugs but IMO, just splice into the wires like my post.
Old Jul 12, 2004 | 10:54 AM
DaX's Avatar
DaX
Loved
Community Favorite
I used the plugs, in case I wanted to go back and use Saturated [high impedance] injectors later on...therefore I wouldn't have to cut and solder again...only a plug and play matter.
Here are some pics [shown with the resistor box out of the loop]:
Sorry you can't see around the clutch MC very well. If you're interested, I could take some better pictures later.
Old Jul 12, 2004 | 11:01 AM
Default Re: Resistor box question...did a search (ladysman)
so where if it is plug and play do i plug it into...what connector
Old Jul 12, 2004 | 11:13 AM
ladysman's Avatar
Default Re: (DaX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaX &raquo;</TD></TR><TR><TD CLASS="quote">I used the plugs, in case I wanted to go back and use Saturated [high impedance] injectors later on...therefore I wouldn't have to cut and solder again...only a plug and play matter.
Does it work? If you follow how I did it it wouldn't work. I guess I am lost on what you did.
Old Jul 12, 2004 | 11:14 AM
DaX's Avatar
DaX
Loved
Community Favorite
It isn't. You have to solder connectors into an OBD-1 harness to make it plug and play for the future. One way or another, if you're going to run a resistor box on an OBD-1 car, you are going to have to cut and solder some wires.
Old Jul 12, 2004 | 11:57 AM
ok what i have is the whole injector harness with the resistor box. clips and all...all the wiring even the four or 5 wires that go to the ecu from the injectors...can i just swap all that stuff out for the old....
Old Jul 12, 2004 | 12:04 PM
T-RO's Avatar
I was the one with the write up.
Follow these instructions and you dont have to cut any of your OEM wires.
https://honda-tech.com/zerothread?id=736737
Old Jul 12, 2004 | 12:06 PM
also theres a yellow wire coming out of the resistor box from a harness that is hanging loose..where does this go..it goes throught the harness and on the other side its red....
blaketeg
Mar 29, 2013 09:13 PM
ArithMEHtik
Dec 2, 2011 01:39 AM
Hoe Hopper
Dec 15, 2009 08:30 AM
Slow Ek
Sep 2, 2008 04:26 PM
