resistor box. need reference to a picture.
Old Oct 14, 2007 | 11:15 AM
K i l l a B e e.'s Avatar
Default resistor box. need reference to a picture.
hi im wiring up my resistor box directly to my injectors.
this is the picture im using as reference. can somebody tell me how i would connect the red wire to the 4 ecu wires? do i just T them?
Modified by K i l l a B e e. at 1:57 PM 10/14/2007
Old Oct 14, 2007 | 11:22 AM
RC000E's Avatar
Default Re: resistor box. need reference to a picture. (K i l l a B e e.)
You use the 12v junction plug over at the driver side strut tower. There are 7 yellow/blacks there, with 4 of them going to the injectors. Wire the injector (4 out wires from the resistor) to each of the injectors. The remaining three should just be all connected together and connected to the resistors red (power in) wire.
Old Oct 14, 2007 | 12:56 PM
Default Re: resistor box. need reference to a picture. (RC000E)
i have an obd2 motor. my dead end plug is underneath my manifold, i cant seem to get the cap off of the dead end plug.
one other thing. I have a resistor box, but i odnt have the other end of the plug for it. When i received it, they removed the connector and just gave me the resistor box.
Old Oct 14, 2007 | 05:39 PM
that is how i have it wired.
Old Oct 14, 2007 | 05:47 PM
are you suppose to connect the non common color from the injector clips and the ecu together?
Old Oct 14, 2007 | 08:14 PM
RC000E's Avatar
Yes, yellow, blue, red, brown go to their corresponding locations at the ecu. Yes, OBD2 you use the junction underneath...I've done it many times on various swaps in the past. As far as the cap goes, you don't need to get it off to wire the resistor in...it can stay.
So, like I said, identify which of the four in the junction go to the injectors, then wire them to the four black wires on the resistor, combine the other three/four remaining and attach them to the red wire going into the resistor....cake dude...just get it done.
Old Oct 14, 2007 | 08:42 PM
yeah i wired them up, but when my motor starts, i cant pass 3000 rpms. i'm pretty sure its my injectors that are not letting me go pass 3000
Old Oct 14, 2007 | 11:31 PM
RC000E's Avatar
That's highly unlikely to be it. Wiring those is straight forward and almost too simple to f*ck up. Get someone who knows what their doing to check your sh*t.
Is the thing running normally then hitting a brick wall, or is it a sluggish pig all around? You have an engine light? You got other problems I'm willin to bet.
Old Oct 15, 2007 | 09:04 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RC000E &raquo;</TD></TR><TR><TD CLASS="quote">That's highly unlikely to be it. Wiring those is straight forward and almost too simple to f*ck up. Get someone who knows what their doing to check your sh*t.
Is the thing running normally then hitting a brick wall, or is it a sluggish pig all around? You have an engine light? You got other problems I'm willin to bet. </TD></TR></TABLE>
the motor ran well with the turbo off, the only cel i had was the secondary o2 sensor. When i start up the car with the chipped ecu, the car idles pretty smooth. After I hit the throttle, it will rise to about 2600rpms and then be VERY sluggish and not be able to move pass 2600. I am pretty sure i wired it correct, i check like 6 times.
Old Oct 15, 2007 | 11:09 AM
RC000E's Avatar
Dude...I looked in your other thread and there your saying you have a solid CEL...your injectors aren't it like I said. Solid CEL in a chipped ecu either means the installed components are bad/installed wrong or it was a bad chip burn. When the ecu can't reference that chip is goes into limp.
Old Oct 15, 2007 | 02:39 PM
ok cool, how do i check if i have a bad ecu?
Old Oct 24, 2007 | 08:57 PM
jdmray's Avatar
if a ecu has a solid light it could also be a blown diode or transister it just happened to me
dk=gsr
Engine Management and Tuning
Mar 6, 2012 11:20 AM
myessay
Oct 27, 2011 11:42 AM
mpf90
Mar 23, 2009 11:54 AM
bruthaboost
Dec 17, 2001 09:08 PM
