Resistor Box Necessary????
Old Nov 5, 2002 | 10:16 PM
TurboCRVTEC's Avatar
Default Resistor Box Necessary????
hmmm. i put my 450cc dsm squirters in and they seem to work fine so far. just wondering what the resistor box does and why people use them if they work without it? i guess it has a LITTLE, hardly noticeable choppy idle SOMETIMES, but other than that, all good, woudl the box help the idle smooth out a bit? thanks
[Modified by TurboCRVTEC, 4:58 AM 11/7/2002]
Old Nov 5, 2002 | 10:22 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Resistor Box Necessary???? (TurboCRVTEC)
You are asking you computer to supply more current, which can over drive you ecu and fry it. You still have the same voltage, higher resistance, and more current.
Ohms law is V= R * I or I= V/R
As resistance in your injectors is lower, then the current will increase. Dont to it man, I dont care how "smooth" your idle is, dont do it.
Old Nov 5, 2002 | 10:29 PM
falcongsr's Avatar
What is this crap?
Default Re: Resistor Box Necessary???? (Arturbo)
what he said.
eventually you'll fry the output transistors in your ECU.
how good will your idle be then?
Old Nov 5, 2002 | 10:31 PM
Sonny's Avatar
Listen to Arturbo.
Sonny
Old Nov 5, 2002 | 10:43 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Resistor Box Necessary???? (Sonny)
Notice the transistors? Dont burn these.
Old Nov 6, 2002 | 02:51 AM
TeStUdO's Avatar
Default Re: Resistor Box Necessary???? (AfroPuff)
you probably just have rc injectors then, i doubt you have the dsm's with no resistors, if you do i cant believe your ecu hasnt fried yet.
Old Nov 6, 2002 | 09:06 AM
SiRkid's Avatar
i burned them when i accidently did my conversion harness wrong
wasnt too bad... cost like $50 to fix it but thats $50 less that i have for parts.
Old Nov 6, 2002 | 09:50 AM
hmm ok thanks guys. looks like ive got some wiring to do
Old Nov 6, 2002 | 10:26 AM
CovertFI's Avatar
hmmm. i put my 440cc dsm squirters...
What dsm comes with 440cc injectors?
the turbo ones
Old Nov 6, 2002 | 10:32 AM
PM-Performance's Avatar
Default Re: Resistor Box Necessary???? (CovertFI)
i just got the resistor box and the clips and the wiring digram off someone in here for $40 shipped. aint a bad deal . supposedly you can get them from older crx's and civics. try a junk yard. sholdnt be too much .
Old Nov 6, 2002 | 07:48 PM
Acuracy's Avatar
New User
even if your running a standalone like dfi...do u still need the resistor box wit RC 550 injectors?
Old Nov 9, 2002 | 09:51 AM
Acuracy's Avatar
New User
Default Re: Resistor Box Necessary???? (Acuracy)
Anyone can answer that???
Old Nov 9, 2002 | 10:09 AM
Sonny's Avatar
It depends on the system. Some standalones like Hondata, Zdyne, and the AEM EMS require a resistor box. The Haltech does not. It can drive either type of injector.
Sonny
Old Nov 9, 2002 | 01:18 PM
boostaholic's Avatar
DFI has injector drivers to run peak/hold or low impendence style injectors.
If anyone needs injector resistor boxes or clips, i have 3 sets of them for sale. 40 shipped for the resistor box and injector clips or 25 shipped for the box and 20 shipped for the clips.
1badteg
Jan 3, 2011 05:33 PM
Scheizty
Sep 2, 2008 02:40 PM
a1320honda
Sep 6, 2007 12:55 PM
oneforce
May 23, 2007 05:38 PM
hondaZvic
Aug 27, 2002 09:39 PM
