researched turbonetics turbo?????
Old 08-04-2007, 12:21 PM
lsvtechatch92's Avatar
Default researched turbonetics turbo?????
ok i am building a 83mm ls vtec.. but for now i was given a ls motor.... i already had a turbo kit on my lsvtec 81.5mm pistons and rods motor cracked sleeve...
i was given a turbo from a friend today its a turbonetics t3 to4b with .63 ar come from a drag kit for a prelude... any one know what kind of power this t will support on a ls motor... jw did some research and couldnt find it
Old 08-04-2007, 04:06 PM
blinx9900's Avatar
Default Re: researched turbonetics turbo????? (lsvtechatch92)
thats the turbo revhard uses on tehre sohc kits, i say prolly 350 but its really a wild guess.
Old 08-04-2007, 04:23 PM
1fastEK9's Avatar
Default Re: researched turbonetics turbo????? (blinx9900)
its a great turbo I seen it go on the 400hp no problem
Old 08-04-2007, 07:25 PM
Default Re: researched turbonetics turbo????? (1fastEK9)
wonder how many lbs it will take to make around 300 whp
Old 08-05-2007, 01:18 AM
blinx9900's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsvtechatch92 &raquo;</TD></TR><TR><TD CLASS="quote">wonder how many lbs it will take to make around 300 whp</TD></TR></TABLE>
every engine is different, cams/cr/displacement/exhuast/etc... all play a roll, for example i made 300whp on 9.5psi with a t3/t04e and i had a 1.6!!
Old 08-05-2007, 05:27 AM
nsxmatt's Avatar
It will make roughly 400whp on most setups before you'll start to overspin the turbo, as long as the oil seals last that long in the first place.
kartman
12-14-2006 06:55 PM
CustomX113
11-20-2006 09:27 AM
dan's integra
01-09-2006 08:55 AM
buckfittyone
09-05-2003 11:02 PM
HondaHanger
02-18-2003 08:05 PM
Quick Reply: researched turbonetics turbo?????
