Replacing Main Bearings?
Old Oct 23, 2002 | 01:26 PM
filetofit
Guest
Posts: n/a
Default Replacing Main Bearings?
The owner of the machine shop that has done some work for me said that you can replace the main bearings without removing the crank by rotating the old ones out and rotating the new ones in. Anyone ever done this? I'm using ACL bearings so the bearing color is moot.
Old Oct 23, 2002 | 03:29 PM
Blownlude's Avatar
New User
Default Re: Replacing Main Bearings? (filetofit)
A friend of mine did it in an Avenger. They rebuilt the whole motor, put it back in, then had to replace the main bearings again. Needless to say, we didn't want to pull the motor again. So they got under the car and replaced them.
Old Oct 23, 2002 | 04:45 PM
earl's Avatar
I've done it that way before in an emergency. You better know what you are doing.
Old Oct 23, 2002 | 05:10 PM
speedworks's Avatar
Default Re: Replacing Main Bearings? (earl)
yes, it can be done. just be extremely careful not to nick the crank when removing them. make sure to remove all the belts as this will let the tension off of the bearings and will cause them to rotate easier.
[Modified by speedworks, 2:12 AM 10/24/2002]
blackeg
Jul 8, 2010 06:56 PM
akura404
Jul 31, 2006 01:18 PM
b16spaz
Oct 22, 2005 08:24 PM
PHILLIPDEEZ
Jul 17, 2005 10:00 AM
luckypon7
Nov 21, 2003 05:13 PM
