main bearings swap
Old Jul 16, 2005 | 12:21 AM
PHILLIPDEEZ's Avatar
Default main bearings question?
well today we cracked open my d16z6 to find out that the reason for my minor rod knock was beacuse one of my main bearings was completely worn and warped it didnt even fit back in the journal all the way is that normal to have only one really bad bearing wouldnt they all be bad? but we check rest were fine as well as were the rod bearings. so since the car is parked anyway we are going to replace the main and rod bearings me and my friend are pretty new at this but he heard that you can drop the tranny to partially drop the crank and slide the new main bearings in with out completely removing the crank(the motor is still in the car by the way) anyone ever heard of this method or have any ideas as to how we can replace the mains without completely removing the crank? Also if my rod bearings are yellow does that mean the mains are also yellow or is there another code i need to check the block and crank for? thanks guys
Modified by PHILLIPDEEZ at 2:34 AM 7/16/2005
Old Jul 16, 2005 | 06:02 PM
Default Re: main bearings question? (PHILLIPDEEZ)
bump
Old Jul 17, 2005 | 10:00 AM
HYPEBEAST!'s Avatar
BUMPP FOR UNCLE!
jakscivic
Feb 21, 2013 08:27 AM
JScott3d
Jan 6, 2008 09:10 PM
JaHnAbOi
12
Jun 22, 2006 11:00 PM
v4lu3s
Jul 26, 2004 11:25 AM
