Removing Eagle rod cap after plastigaging
Old Apr 9, 2003 | 05:00 PM
VWkila's Avatar
Default Removing Eagle rod cap after plastigaging
I've plastigaged my Eagle rods tonight. And now the rod cap will not budge from the crank!
How you guys removed yours?
Old Apr 9, 2003 | 05:15 PM
TREVER's Avatar
Default Re: Removing Eagle rod cap after plastigaging (VWkila)
Screw the bolts back in about 4 threads then tap the bolt head with a rubber mallet
Old Apr 9, 2003 | 05:19 PM
VWkila's Avatar
Default Re: Removing Eagle rod cap after plastigaging (TREVER)
Thanks for the reply. I thought about doing this actually, but afraid I'd bend something.
Old Apr 9, 2003 | 09:18 PM
Flamenco-T's Avatar
tap one side, until that side lifted up slightly, then do the other side abck and forth until you can pull them out
stan
Old Apr 9, 2003 | 09:44 PM
earl's Avatar
Default Re: Removing Eagle rod cap after plastigaging (Flamenco-T)
wazzup Stan...see you in a couple of days
Old Apr 9, 2003 | 09:55 PM
Flamenco-T's Avatar
Default Re: Removing Eagle rod cap after plastigaging (earl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl &raquo;</TD></TR><TR><TD CLASS="quote">wazzup Stan...see you in a couple of days
I have been dying to see you earl....
stan
Old Apr 9, 2003 | 10:04 PM
Darin D.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TREVER &raquo;</TD></TR><TR><TD CLASS="quote">Screw the bolts back in about 4 threads then tap the bolt head with a rubber mallet</TD></TR></TABLE>
That is how i've always done it as well, but it seems like doing it this way might possibly crush the plastigauge more since when you tap on the bolt the rod pulls down on the cap until it breaks loose....i've never had a problem though. I don't think theres another way to do it.
Old Apr 9, 2003 | 10:36 PM
earl's Avatar
Default Re: Removing Eagle rod cap after plastigaging (Willis)
Whatch u mean Willis? SORRY, I always wanted to do that. I might dock myself a point.
As long as you tap the bolt, you will not affect the plastigage. Just don't hit the rod itself, only the bolt
Old Apr 10, 2003 | 12:01 AM
V-SPEC 1's Avatar
A little bit off topic but same parts:
When you install the eagle rods in LSvtec set up, which side is the rod should face? i.e there's # on the other side. I heard the what some people saying that is "tang to exhaust" is it right? Thanks.
Old Apr 10, 2003 | 12:27 AM
boostaholic's Avatar
Default Re: Removing Eagle rod cap after plastigaging (boostedb20vtec)
There are two tangs to hold the bearing in place on the big end. Both of the tangs should face the exhaust side.
Old Apr 10, 2003 | 03:23 PM
earl's Avatar
Default Re: Removing Eagle rod cap after plastigaging (boostaholic)
Tang to the exhaust but Eagle claims that their rods are the same in either direction. So don't panic if you put in some Eagles and didn't check. This may not be true for stock and other brands of rods.
Old Apr 10, 2003 | 05:46 PM
VWkila's Avatar
Umm... this won't work. there are no thread on the cap side of the rod.
Old Apr 11, 2003 | 10:44 PM
V-SPEC 1's Avatar
Thankyou Earl, now I'm not worried after all.
TealEG!
May 21, 2008 02:52 PM
SPOOLINmatt
Apr 4, 2007 06:27 AM
Dublocivic
Dec 13, 2005 05:46 PM
riceball777
10
Oct 14, 2003 11:56 AM
BlueSi2k
May 4, 2003 07:49 PM
