Recommended Guages
Old Jul 22, 2006 | 02:49 PM
  #26
SavEM1's Avatar
d or b series?
Old Jul 22, 2006 | 05:26 PM
  #27
shorty5198's Avatar
Default Re: (Hcivic02)
d series. '03
Old Jul 22, 2006 | 05:30 PM
  #28
TurboEM1's Avatar
Default Re: (shorty5198)
Boost (obvious to check for boost spikes and to make sure wastegate is working)
Oil Pressure (so you engine never starves for oil and you can detect early oil pump failure)
Water Temp (so you can tell how hot your car is getting and if you need to let it cool, the stock guage is innacurate and the middle position is actually for a range of temps not just a specific one)
You dont need EGT, oil temp, tranny temp or a/f (unless its a wideband),
Old Jul 22, 2006 | 05:46 PM
  #29
SavEM1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shorty5198 &raquo;</TD></TR><TR><TD CLASS="quote">d series. '03</TD></TR></TABLE>
ouch . Those D17s are really stubborn NA or FI. For what it's worth, i'd save and get a K20a3 or even a k24 motors, I would definitly pick one of those up (i see them cheap complete all the time CHEAP) and build that up and boost that. Even after the turbo setup i'd suspect you'd hit high 14s...I've delt with them before and they are (and it was an auto)
How much psi do you plan on boosting?
Old Jul 22, 2006 | 06:13 PM
  #30
shorty5198's Avatar
7.5 on a t-25
Old Jul 22, 2006 | 06:16 PM
  #31
turbotime's Avatar
oil pressure, boost/vac and wb02
i recommend the plx m300 for wb
Old Jul 22, 2006 | 06:19 PM
  #32
SavEM1's Avatar
Oh and about guages, id run wideband, oil pressure, and boost. But since you say you are on a budget I doubt you would be able to run one so I'd just get oil pressure and boost...no need to waste money on a 3rd guage.
Old Jul 22, 2006 | 06:31 PM
  #33
shorty5198's Avatar
just out of curiosity, how much more would a k20 swap be as opposed to just a tranny swap for my d17
Old Jul 22, 2006 | 08:10 PM
  #34
SovXietday's Avatar
K swap ~ $6000
D17 = a whole lot of headaches.
I'd really talk your rents into selling so you can go with a 5th or 6th gen Civic.
Old Jul 22, 2006 | 09:21 PM
  #35
SavEM1's Avatar
Default Re: (SovXietday)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SovXietday &raquo;</TD></TR><TR><TD CLASS="quote">K swap ~ $6000
I'd really talk your rents into selling so you can go with a 5th or 6th gen Civic.</TD></TR></TABLE>
he doesn't have to swap in a a2 or whatever....
You can go with a k20a3 (EP3 motor) or a K24 (TSX) motor, both will have a lot more potential than your d-series for boost (as long as they are built, but they are both sucky on the NA end) You could probably find a 24 and a3 swap for 2-3k including tranny. Way easier to swap a K in the 7th gen.
edit: sell off the d17 for around 600-800 bucks as well.
Old Jul 23, 2006 | 09:00 PM
  #36
shorty5198's Avatar
I think these are kinda cool. They are pretty cheap though. Are they pretty micky mouse or are they alright. http://www.glowshiftdirect.com...ry=24
Old Jul 23, 2006 | 09:06 PM
  #37
SavEM1's Avatar
http://www.42draftdesigns.com/vdo.htm
Old Jul 23, 2006 | 09:29 PM
  #38
teamsoy1320's Avatar
you could use a volt gauge
Old Jul 23, 2006 | 09:49 PM
  #39
shorty5198's Avatar
i think i'm gunna go with those glowshifts. I'm goin wiht pyrometer, boost, and oil pressure(to see if i'm leakin oil).
pjr710
Jun 9, 2008 04:46 PM
mr abstract
Jan 23, 2007 02:00 PM
RTW DC2R
Apr 25, 2006 01:18 PM
94turbodelsol
Jan 7, 2006 02:45 AM
SPOON 1
Sep 30, 2003 08:36 AM
