recirculate dumptube into downpipe?
Old Nov 28, 2006 | 08:35 AM
doood's Avatar
been there done that
Default recirculate dumptube into downpipe?
i've already tried searching on this topic but couldnt find anything. i've heard that by having the wg dumptube recirculate back into the downpipe you'll actually get a few more hp and it wont be so loud. but i've also heard that by dumping to open atmosphere it can give a faster spool because the wastegate is met with no backpressure at the expense of more noise. any truth to either statements?
Old Nov 28, 2006 | 12:35 PM
RedEj8's Avatar
Default Re: recirculate dumptube into downpipe? (that one doood)
Its true that recirculating the wastegate into the downpipe will make it more quiet, but im pretty sure you wont gain any hp at all by doing this. If that was true then race cars would have the dumptube connecting to the downpipe.
Old Nov 28, 2006 | 12:45 PM
Mugencrxsir1's Avatar
Default Re: recirculate dumptube into downpipe? (RedEj8)
if it's a sound issue, and you don't want to redesign your dump tube, then put a $10 lawn mower muffler on there. You can find them in very small sizes, and are very quite. I've done that before, and learned that trick from the domestic community
Old Nov 28, 2006 | 01:18 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: recirculate dumptube into downpipe? (Mugencrxsir1)
it can effect performace if the turbo is sucking up the exhaust from the dumbtube if its not routed the right way
Old Nov 28, 2006 | 01:32 PM
JDogg's Avatar
Default Re: recirculate dumptube into downpipe? (S@nt0s)
if you route it back in 3ish feet from the turbine outlet it wont hurt much, but any closer and you will sacrifice a good ammount of power and it will slow the spool a good ammount b/c of added backpressure in the exhaust
Old Nov 28, 2006 | 01:33 PM
STEELCITYEVO8's Avatar
just make sure u dump down and away from intake so the turbo dosnt pull back exhaust. i was hessitant about dumping to atmosphere cause of noise but now i wouldnt want it any other way! imo.
Old Nov 28, 2006 | 01:38 PM
EJ1 wilcox's Avatar
Default Re: (STEELCITYEVO8)
I love the sound of an open dump tube.
It's not like it's loud when you are just driving. It's only loud when you are at full boost, which means you are really getting on it, and at that point you are just trying to hold on to the steering wheel, much less worry about how much noise you are making. lol
Old Nov 28, 2006 | 02:05 PM
platinum00's Avatar
if you search you will find your answer.
Old Nov 28, 2006 | 06:39 PM
markaria's Avatar
Default Re: (EJ1 wilcox)
at that point you are just trying to hold on to the steering wheel, much less worry about how much noise you are making. lol[/QUOTE]
...I know that feeling
Old Nov 28, 2006 | 06:45 PM
bb_one's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ1 wilcox &raquo;</TD></TR><TR><TD CLASS="quote">I love the sound of an open dump tube.
It's not like it's loud when you are just driving. It's only loud when you are at full boost, which means you are really getting on it, and at that point you are just trying to hold on to the steering wheel, much less worry about how much noise you are making. lol</TD></TR></TABLE>
Pretty much sums it up
Old Nov 28, 2006 | 06:46 PM
0bd1_Kanobe's Avatar
Default Re: (markaria)
ME like loud wastegate's
Old Nov 28, 2006 | 09:08 PM
doood's Avatar
Default Re: (0bd1_Kanobe)
thanks for the info
Old Nov 28, 2006 | 09:41 PM
mrbh22's Avatar
Default Re: (that one doood)
if it is a sound issue then yes recirculate it, and yes you will lose hp not alot but in essense you are making your exhaust smaller, by adding extra air into a confined space.
Old Nov 28, 2006 | 09:56 PM
doood's Avatar
Default Re: (mrbh22)
well i wasnt really concerned with noise as i plan to run an e-cutout. was just curious as to whether or not their was any truth behind those statements.
ITR-T-GUY01
Nov 4, 2005 01:12 PM
Sprockets
Sep 23, 2005 09:56 PM
.RTErnie
May 4, 2005 04:41 AM
twkdCD595
Sep 29, 2002 10:43 PM
92HB_HB
May 15, 2002 04:48 PM
