Recieved my new block
Old Dec 20, 2001 | 03:13 PM
jdmciviceg's Avatar
New User
Default Recieved my new block
I just recieved my new (to me/ used) b18c1 block. It was a race eng block guard, SRP pistons and eagle rods. The block guard is a little uneven. Most of it is about 1/8 to 1/16 of a inch below the top of the block and cylinder walls but in 1 spot it is flush with the top. Can I just tap it down so its even again or will this mess up anything?
Thanks
Old Dec 20, 2001 | 03:47 PM
SiR Kid's Avatar
New User
Default Re: Recieved my new block (jdmciviceg)
As long as it's not tack welded, yeah, just tap it with a rubber mallot til it's sunk down, then with a screwdriver or something.
You get that from Josh, Dave?
[Modified by SiR Kid, 6:48 PM 12/20/2001]
Old Dec 20, 2001 | 04:46 PM
WykidEH's Avatar
Default Re: Recieved my new block (SiR Kid)
That's Josh posting under a friends name. . . . .
Old Dec 20, 2001 | 08:14 PM
hybrid901's Avatar
Default Re: Recieved my new block (WykidEG6)
Yeah it was me at work. Will pushing the block guard down the sleeve move the cylinders at all. Is there any need to get it spot welded in place?
Old Dec 20, 2001 | 08:22 PM
DamonBoost's Avatar
New User
Default Re: Recieved my new block (hybrid901)
Just thought I would say WHATS UP GUYS!!!! nice to see you on this board!!!
Old Dec 20, 2001 | 09:54 PM
SiR Kid's Avatar
New User
Default Re: Recieved my new block (Damon501)
Hmmm It shouldn't change any geometry, but I'd let Bobby measure all the angles if you're that concerned... Make sure all the cylinders are at the same angle.
Old Dec 21, 2001 | 06:37 AM
hybrid901's Avatar
Whats the farthest I can push the block guard down with out messing anything up?
Old Dec 21, 2001 | 07:06 AM
rtype11's Avatar
it should stop on its own from tapering out of the sleeves at 1/4" max, i suggest you find a way to gently get it out, then throw it in the freezer for a few hours and then just drop it in.
Old Dec 21, 2001 | 09:23 AM
SiR Kid's Avatar
New User
Default Re: Recieved my new block (rtype11)
Good idea rtype11.... never thought of that.
Old Dec 21, 2001 | 09:26 AM
WykidEH's Avatar
Right on man!
Just take it to H/Q.
Old Dec 21, 2001 | 10:30 AM
hybrid901's Avatar
Don't the cylinders have to be bored with the block guard in, so pulling it out might **** it up correct? Is it ok being flush with the top of the cylinders?
Rickcrx
Feb 23, 2012 05:18 PM
EJ1_228
Mar 25, 2008 11:26 PM
Soon_2b_evil
Aug 8, 2003 06:40 PM
pbomers
Jun 30, 2002 06:41 AM
