Rebuilding a turbo
Old Oct 6, 2002 | 04:40 PM
fire7882's Avatar
Default Rebuilding a turbo
Can this be done with simple tools? I have all the parts but i have also heard that something needs to be balanced. Has anyone done their own turbo rebuild? How did it turn out and what did you have to do?
Thanks
[Modified by fire7882, 8:41 PM 10/6/2002]
Old Oct 6, 2002 | 05:47 PM
MiraiZ's Avatar
Default Re: Rebuilding a turbo (fire7882)
I think there is a kit you can buy online for about $100 that has all you need to do a turbo rebuild...forgot where the link is though
Old Oct 8, 2002 | 09:35 PM
fire7882's Avatar
Default Re: Rebuilding a turbo (MiraiZ)
i got a kit off ebay for 60 dollers. i just need to know about this balancing thing. Anyone???
Old Oct 8, 2002 | 09:52 PM
inspyral's Avatar
You can replace the seals and whatnot yourself, but I'm pretty sure the balancing of the shaft isn't really a DIY kind of thing.
Old Oct 8, 2002 | 10:05 PM
fire7882's Avatar
Default Re: Rebuilding a turbo (inspyral)
Well, if i just replaced the seals and bearings, will the shaft need to be balanced again, considering it was balanced from the factory and i'll still be using the same shaft.
Old Oct 9, 2002 | 12:46 AM
T-sohctec's Avatar
They don't balance the shaft, they balance the wheels.
Hence if you want to keep the proper balance, Just mark the compressor wheels position relative to the shaft.
This is assuming no damage has occured to the turbine or compressor wheel.
Old Oct 9, 2002 | 06:26 AM
fire7882's Avatar
Default Re: Rebuilding a turbo (T-sohctec)
Thanks for that info. I think i'm going to give it a try.
cityofcaterpillars
Apr 22, 2016 12:21 PM
nekoabandoned
Jan 10, 2006 08:45 AM
civictypenos
Oct 28, 2002 07:02 AM
bigTom
Oct 10, 2001 09:07 AM
