rebuild turbo seals bearing how much???
I have to replace the seals and bearing on my t3. I got a kink in my return line and had oil coming out of everywhere but the bearing has a lot of play as well, so i am going to replace it all at once. What is an average price for it to be rebuilt balanced etc. I have heard that the bearing is only like $60 and seals are nothing at all, but just really need to get the car back on the road.
Thanks
already did search and came up with nothing.
Thanks
Re: rebuild turbo seals bearing how much??? (wreckedagain)
we do a full service/rebuild, seals, bearings and full assembly balance all for just $250 with free return shipping.
http://store.yahoo.com/cheapturbo/fullrebuild.html
Re: rebuild turbo seals bearing how much??? (CHEAPTURBOdotCOM)
When I blew my turbo, I called John Craig and bought his rebuild kit for $90. It comes with a video on how to do it yourself. Takes approximately a hour and fifteen minutes. Anyone with mechanical experience can do it. Balancing is only required if you change the core. If your fins on the turbo are good, do it and save yourself some coin. Check this link for details.
http://www.gnttype.org/techarea/turbo/turborebuild.html
Re: rebuild turbo seals bearing how much??? (MIKES)
i did mine and it leaked after a wile, i think the shaft was wobbly. i would recomend you at least sending the shaft off to get checked
Re: rebuild turbo seals bearing how much??? (CovertFI)
Thanks for all the help, i am going to send it outjust to make sure everythig checks out fine.
98lude
09-07-2001 06:59 AM
