good compression numbers with ls turbo...
Old Nov 20, 2003 | 01:30 PM
B_1_8_hatch's Avatar
Default good compression numbers with ls turbo...
what would good compression numbers be having an ls turbo?
Old Nov 20, 2003 | 01:36 PM
PureTeg420's Avatar
Default Re: good compression numbers with ls turbo... (93hb)
Stock I pulled 200 across
Old Nov 20, 2003 | 01:37 PM
Default Re: good compression numbers with ls turbo... (PureTeg420)
200? i thought those would be numbers for a gsr motor?
Boltz's Avatar
i dont think the turbo would affect the compression numbers, no idea what LS's ussually do but im sure good compression numbers for a stock ls= good compression numbers for turbo ls. i think that consistency between cylinders is more important.
somone correct if im wrong about the turbo na theory
Old Nov 20, 2003 | 01:39 PM
Default Re: good compression numbers with ls turbo... (FourceFed)
i guess i'm looking for is where should the compression numbers be around for an ls motor for it to be considered a good motor? i've seen ranges from 150 across up to 200 across the board.
Old Nov 20, 2003 | 01:41 PM
PureTeg420's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FourceFed &raquo;</TD></TR><TR><TD CLASS="quote">i dont think the turbo would affect the compression numbers, no idea what LS's ussually do but im sure good compression numbers for a stock ls= good compression numbers for turbo ls. i think that consistency between cylinders is more important.
having a turbo on will not affect any compression readings.
Most of the stock GSR's I've checked have been around 215-225..where as LS's tend to fall around 190-200
Boltz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93hb &raquo;</TD></TR><TR><TD CLASS="quote">200? i thought those would be numbers for a gsr motor?</TD></TR></TABLE>
ive seen gsr's pull 240
Old Nov 20, 2003 | 01:42 PM
mskibbz-T's Avatar
I was 205 210 205 210 in my LS
Old Nov 20, 2003 | 01:47 PM
streetrage's Avatar
the Hayne's manual says that the Maximum Compression (psi) is 185 (practically new) and the lowest to be considered healthy is 135 or something like that.... But you can have higher compression than 185 sometimes, like if you have carbon deposits on your cylinder head..
Alex
Old Nov 20, 2003 | 02:03 PM
sounds good. i got 170 across
Old Nov 20, 2003 | 04:01 PM
ndogg's Avatar
my gsr has 250 across.
Old Nov 20, 2003 | 04:12 PM
quikB18B's Avatar
Default Re: good compression numbers with ls turbo... (ndogg)
My Ls motor is 165 across the board
Old Nov 20, 2003 | 05:35 PM
DIRep972's Avatar
Smarter than you
180-190 is what mine did.
Old Nov 20, 2003 | 05:40 PM
Ben Huynh's Avatar
The exact compression numbers will vary from engine to engine. As long as you keep your numbers within a 10% variance, you're fine.
Old Nov 20, 2003 | 05:42 PM
nevin's Avatar
Default Re: good compression numbers with ls turbo... (quikB18B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quikB18B &raquo;</TD></TR><TR><TD CLASS="quote">My Ls motor is 165 across the board</TD></TR></TABLE>
Old Nov 20, 2003 | 07:18 PM
spooln6's Avatar
Default Re: good compression numbers with ls turbo... (nevin)
mine pulled 190 across the board.
Old Nov 20, 2003 | 07:46 PM
DownBoyDown's Avatar
Haynes says for a b18b:
"standard..................199psi"
"Minimum..................140psi"
"max variation between cylinders..........28psi"
B18C1 & B18c5 are the same as above except that the standard is..........270psi
Old Nov 20, 2003 | 07:52 PM
1.8t's Avatar
Default Re: (DownBoyDown)
mine stock was 199, 200, 200, 205
redDAinteg
May 25, 2005 04:31 PM
TenaciousC
Aug 20, 2002 10:31 PM
TenaciousC
Aug 20, 2002 05:48 PM
TenaciousC
Aug 20, 2002 04:55 PM
