REAL QUICK: IS NO2 FI or not?
Old Aug 25, 2007 | 05:43 PM
Ryank327's Avatar
Default REAL QUICK: IS NO2 FI or not?
SO is nitrous considered forced induction? I believe it is, if not please tell me why.
Old Aug 25, 2007 | 05:45 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: REAL QUICK: IS NO2 FI or not? (Ryank327)
real quick, yes
anything other than the 14.7 +- psi of the atmosphere pushing your sir in, is forced.
Old Aug 25, 2007 | 09:46 PM
Coppertop's Avatar
Default Re: REAL QUICK: IS NO2 FI or not? (boostedcivicsir)
ok sorry for the sake of debate and maybe ill learn something from this
when you spray the nitrous its being shot out of the jet but the engine sucks it in, so is it still forced induction?
Old Aug 25, 2007 | 10:25 PM
almostboostedgsr's Avatar
Default Re: REAL QUICK: IS NO2 FI or not? (Granger)
Yes it is considered forced induction. No2 is also considered to be a liquid supercharger.
Old Aug 25, 2007 | 11:18 PM
Drew Peacock's Avatar
Your forcing added oxygen in.
Old Aug 26, 2007 | 12:08 AM
RC000E's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Granger &raquo;</TD></TR><TR><TD CLASS="quote">ok sorry for the sake of debate and maybe ill learn something from this
when you spray the nitrous its being shot out of the jet but the engine sucks it in, so is it still forced induction?</TD></TR></TABLE>
Well, to be truly correct, your motor isn't sucking anything. Atmospheric pressure is forcing itself in to an area of lower pressure. Same with your lungs, you aren't sucking in air, air is force filling your lungs.
Forced Induction is technically defined as increasing the quantity of oxygen introduced into the combustion chamber, beyond that which the motor can acquire on it's own naturally.
Old Aug 26, 2007 | 05:47 AM
dropcivic's Avatar
Devils advocate here, but the manifold is still under vaccum even when you are spraying.
The old school guys called it NA; all motor was no spray or supercharger.
Old Aug 26, 2007 | 06:05 AM
Mr. Badwrench
Default Re: REAL QUICK: IS NO2 FI or not? (dropcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dropcivic &raquo;</TD></TR><TR><TD CLASS="quote">Devils advocate here, but the manifold is still under vaccum even when you are spraying.
The old school guys called it NA; all motor was no spray or supercharger.</TD></TR></TABLE>
WRONG!
AT WOT, THERE IS NO MANIFOLD VACUUM!
again as i said above, anything other then the atmosphere pushing air in, even out of a nozzle, is forced induction, the bottle is under pressure isnt it?
Old Aug 29, 2007 | 04:50 AM
quicksilver1689's Avatar
i ♥ snails
hahah this threads retarded.
i ♥ snails
Default Re: REAL QUICK: IS NO2 FI or not? (RC000E)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RC000E &raquo;</TD></TR><TR><TD CLASS="quote">
Forced Induction is technically defined as increasing the quantity of oxygen introduced into the combustion chamber, beyond that which the motor can acquire on it's own naturally.</TD></TR></TABLE>
mike93eh2
Nov 29, 2006 08:41 AM
Azn Kenny
Apr 21, 2006 02:35 PM
whatVTEC
Dec 4, 2003 05:31 AM
2k1 GSR
Oct 27, 2003 08:06 PM
4DooRGiSzer
Jun 17, 2003 08:29 AM
