ready to boost ALMOST DONE!
Old Apr 8, 2013 | 08:59 PM
jonesEK's Avatar
Default ready to boost ALMOST DONE!
Hi guys im ready to boost my 2000 civic ex
I have an edelbrock kit but I plan on getting tuned on crome
blue top 450cc dsm injectors
a chipped p28 ecu
aem wideband o2 sensor
arp headstuds
(probably forgetting something ill add it later if I remember)
I also have a 3'' exhaust
I plan to get a 3'' downpipe because The edelbrock one is a 3'' but bottlenecks at the cat to 2.25''
I plan on getting tuned at Importautopros in Westminster ca
what else do I need??
Thanks guys
EDIT:
also have a 255lph? walbro fuel pump
Old Apr 8, 2013 | 10:59 PM
YuckyCorpse's Avatar
Default Re: ready to boost ALMOST DONE!
get rid of the cat. or get a 3 inch.
Old Apr 9, 2013 | 12:08 AM
jonesEK's Avatar
Old Apr 9, 2013 | 03:47 AM
Muckman's Avatar
Moderator in Chief
3" exhaust is a complete waste if it crams into a 2.25" cat.
Old Apr 9, 2013 | 04:17 AM
sirtef9's Avatar
^^ true, go with a 3" cat if your hell bent on running one.
Old Apr 9, 2013 | 05:45 PM
jonesEK's Avatar
a chipped p28 ecu
arp headstuds
Thanks guys
EDIT:
guess I should have said cat too
this isn't as much help as I thought it would be
anything else I need?
I was thinking an oil cooler but not too sure
Old Apr 9, 2013 | 06:35 PM
TheShodan's Avatar
Moderator
An oil cooler would not help you in this case at all. Unless you plan on road racing the car.
Old Apr 10, 2013 | 05:52 AM
jonesEK's Avatar
thanks...
anything else?
Old Apr 11, 2013 | 07:16 PM
jonesEK's Avatar
bump
Old Apr 11, 2013 | 07:22 PM
SlowPokeEg's Avatar
Mike Jones
That's the beauty of Hondas (and D-series), you don't need much.
Make sure you have a fresh set of plugs.
Did you do a compression test on the car beforehand? Couldn't hurt to have that on record to see in the future if you're gaining some blowby.
Speaking of blowby, do you have a breather? Catch-Can?
Old Apr 11, 2013 | 08:03 PM
jonesEK's Avatar
no.. no catchcan just a breather filter on the vc
so just slap everything on and go get tuned
Old Apr 12, 2013 | 06:26 AM
h22-eg-hatch's Avatar
You should get a breather kit on this before u shoot the dipstick out and blow your rings out
I learned the hard way...
It was fun boosting until I had to pull the motor. Haha fun while it lasted.
Guaranteed it would have lasted way longer w a good catchcan setup
Laserjock
Apr 16, 2005 09:50 PM
phreakmang
Nov 28, 2003 07:06 PM
JMinSi2000
May 28, 2002 12:52 PM
