Piston ring tech question
Old Jul 26, 2014 | 04:57 AM
Pullig's Avatar
Default Piston ring tech question
Building a b18 for boost looking for around 550wheel .
Ge sleeved 81mm honed to .0045 ptw cp pistons
Question is. Top ring filed out at .020. Which was target. Now second ring is measuring in at .027. The book says .004-.008 bigger than top ring. In your personal experience do you think that will be fine as is?
I have tried 2nd ring from the other 3 boxes I have and they are very consistent.
Old Jul 26, 2014 | 06:02 AM
boosted94gsr's Avatar
Default Re: Piston ring tech question
What brand pistons and rings do you have?
I have heard of people running 2nd ring gaps that big with forged pistons and not have issues. Its the first ring that makes the compression anyways. The 2nd ring gap needs to be bigger to let any pressure that gets by the first ring out to prevent top ring "flutter".
If your 2nd ring gaps are that big out of the box what did the oil ring gaps come out to??
Old Jul 26, 2014 | 08:16 AM
Pullig's Avatar
Cp
.020ish oil ring. I wasn't too worried abt being exact as long as it was between .015 and not larger than 0.050
Also I knew the 2nd ring needed to be larger then top for the reason you explained but from my calculation I had initially planned out .024 2nd ring.
Oh well it is what It is I guess
Old Jul 26, 2014 | 11:18 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
You are more than fine with those numbers. Have fun.
Old Jul 27, 2014 | 06:22 AM
wantboost's Avatar
Who is Mr Robot?
It'll be a little noisy on cold starts/warmup due to piston slap with a p2w that big but other than that you should be fine.
just remember to put the rings in right side up and clock them right. I've seen so many detailed ocd people forget about those 2 details during final assembly lol
Old Jul 27, 2014 | 06:34 AM
blackeg's Avatar
although my bore is a bit bigger than yours, im also at .027 on the 2nd ring. its all good you are fine
MastaFlyMason
Engine Machining & Assembly
Dec 14, 2017 04:08 PM
HybridKOOP
Dec 5, 2011 10:53 PM
maddog20
Jan 22, 2004 04:49 AM
b20ek
Jun 6, 2003 06:14 AM
Plan B
Dec 10, 2002 07:40 PM
