RC 310cc and afc hack?
Old Feb 2, 2003 | 03:40 PM
specie's Avatar
Default RC 310cc and afc hack?
I'm planning on running about 8psi on a t3/t4e on a ls longblock, I was wondering if adding fuel (afc) to the 310 would be enough to sustain 8psi. Or do I definitely need the fmu (I uess 8:1 disk) to provide enough fuel?
Maybe I should trade/sell these for some 450cc?
Old Feb 2, 2003 | 03:49 PM
rjardy's Avatar
Default Re: RC 310cc and afc hack? (specie)
it will work, use the search feature.
Rob
Old Feb 2, 2003 | 08:27 PM
specie's Avatar
Default Re: RC 310cc and afc hack? (rjardy)
I used the search but couldn't come up with much. Thanks.
I read that Greddy uses the blue box, would a safc work as well?
I read that 310cc is good to 200-225, wouldn't 8psi on a t3/t4e be very close to the limit?
Old Feb 2, 2003 | 08:29 PM
wickedxboi's Avatar
you might need something bigger.....at least 440cc. you need to go pass -35% on the afc to trick the map sensor....im sure you can find some stuff if you do a search.
Old Feb 3, 2003 | 08:00 AM
specie's Avatar
Default Re: RC 310cc and afc hack? (wickedxboi)
Yeah, I'm still stuck on a dilemma.
I don't have enough money for an aem and to complete the turbo kit. So I'm thinking maybe just a fmu (8:1) and these, plus check valves. Or should I go with a SAFC with DSM 450cc and not have to worry about check valves, but I get to adjust the fuel..
Old Feb 3, 2003 | 08:22 AM
rioninja's Avatar
I would go with the afc/dsms.
If your really strapped for cash, get an SMC.
Old Feb 3, 2003 | 08:25 AM
Smashback's Avatar
Didn't work on mine, running 7 PSI would throw codes all over the place. Might work with like 3 PSI or something
Old Feb 3, 2003 | 08:38 AM
specie's Avatar
Default Re: RC 310cc and afc hack? (Rioninja)
Yeah, I'd rather get the afc since it would have better resale value.
Would I have a harder time starting the car with larger injectors?
Thanks all.
Old Feb 3, 2003 | 09:52 AM
KC GSR's Avatar
My car cranks right up every time...I noticed no difference in how it starts
Old Feb 3, 2003 | 10:18 AM
turbosol's Avatar
Default Re: RC 310cc and afc hack? (KC GSR)
KC GSR, what do you run your idle settings at? -__% on the afc and what fuel pressure. My car takes a bit more turns to start with the 450s.
Old Feb 3, 2003 | 06:56 PM
KC GSR's Avatar
Default Re: RC 310cc and afc hack? (turbosol)
-25% from 1000rpm and below...i'm have stock fuel pressure. My whole fuel system is stock, the only thing different are the 450s and the afc.
Old Feb 4, 2003 | 06:48 AM
turbosol's Avatar
I have a walbro and fpr, once the fuel pump was installed I couldn't get my pressure back to stock, even with the fpr. So I fun pretty rich at idle.
Tex Blackwell
May 17, 2004 09:15 AM
chbtek9
Mar 8, 2004 06:05 PM
kHoA DoGG
May 14, 2003 11:29 PM
deebee-II
Apr 23, 2003 09:28 PM
Hybrid
Sep 13, 2002 05:56 AM
